Watch_Dogs 2GB vram Performance Analysis and Graphics +337.88 Driver Improvement
20K views 96 replies 36 participants last post by  StrongForce
#1 ·
Since I was one of those lucky individuals who got a copy of Watch Dogs shipped early I thought that I was going to do a thread for the curious and those who want to see how the PC version looks and runs, especially on 2GB cards.
How do you have Watch Dogs already?
I ordered from the Ubishop who happened to had shipped it Wednesday, the game arrived on Friday.
This is to debunk any "Piracy" comments which have been going around, yes there are pirated versions around but those who purchased physical copies, whether it be the Ded Sec Edition, Standard or uPlay Exclusives are able to install the game, input their code and play, everyone told me you wont be able to play uPlay copies but that doesn't seem to be the case, aslong as you have a Physical copy they work, other Ubisoft titles may be the same, I'm unsure.
Bare in mind that this game isn't officially released yet, drivers and patches are bound to follow.
I'm running on the latest Nvidia 337.81 drivers, and this install of windows is a month old.
Update: New drivers apparently hitting tomorrow, I'll most likely test it again with these drivers.
337.88 drivers are available!
Graphical Settings
Graphical Quality
Display
Resolution
Refresh Rate
Aspect Ratio
Window Mode
VSync (Off)
GPU Max Buffered Frames
Textures
Anti-Aliasing (OFF, FXAA, Temporal SMAA, MSAA, TXAA)
Wide Screen Letter Box (On/Off)
System Specifications
CPU: AMD Phenom II X4 B55 @4GHz
GPU: Nvidia MSI GTX760 Hawk (Onpar with GTX670)
Memory: 6GB DDR3 @1333MHz
Framerate 30-40 average, I dont think I've seen a dip below 30 and if it does something crazy has happened on screen and it usually shoot back up.
I'm overwhelmed by how well this game performs and how it handles the hardware, It's using all of my cores to the fullest (4 cores with really high utilization), something I've rarely seen from games, especially Ubisoft's recent Assassin's Creed 4, if this scales up-to 8 threads I dont know, but with the recent threads of requiring 9000 CPU score in Passmark that may be the case, and if so that's brilliant! Were finally starting to see 4+ cores getting used, and in an open world game which are CPU bottleneck prone.
Even now my CPU is a bottleneck, but it's coming close to the end of it's 4 year run, at various points I'm getting 30fps and utilization of around 79-80% showing blatant bottle-necking, with a more capable processor I think I'd be able to pull of 35-40+ average with my current "Optimal Settings" I've written below.
This game uses The Disrupt, a new game engine from Ubisoft, this game was supposedly built for PCs initially and scaled down to consoles
Performance
The 2GB Vram question, a couple of threads have blown up on OCN concerning the 3GB vram that is said to be required for Ultra textures, is this true or not?
From my experience this game in it's current state, whether it's in need of drivers or a patch can stutter on various setups, even cards with higher amounts of ram.
Stutter prone settings
This is all based on my experience with my GPU, other setups which enable settings like these may not encounter stuttering as I do.
Ultra Textures
This is the killer right here, from my experience turned my game into a stutter fest. If you've got 2GB stick to the one just below this, "High".
Ambient Occlusion
For some reason once I apply HBAO+ High, the frame-rate is stable, however it'll begin stuttering,
Any application of Anti-Aliasing other than FXAA, and Temporal SMAA results in stuttering, this could be the game using 2GB of ram, or it could be smoothed out in a patch or driver, if someone had a 2GB and a 4GB card to test with that may help clear up this confusion.
Shadows
When Ultra Shadows are applied once again stuttering can occur, and within my tests quite frequently at times, as I said before drivers and patches are to be expected so some of these problems which are happenning on various systems may become less severe after the first few patches of this game. Having all three of these settings, HBAO+ High, with Ultra shadows and Ultra textures will easily turn this game into a slideshow.
If this is currently affecting a vast majority of 2GB cards I suggest to those who have these cards to attempt to not enable those 3 settings if you're trying to max the game out, however if you're running lower resolutions or not attempting to run the game's settings full blast at Ultra you may be able to run the game with these settings enabled, this could be due to freed vram if these cards are hitting a vram wall. if requested I'll be happy to try it out. I'm almost 99.9% certain my card has the power to run these settings as It's performing as GTX670 (The MSI Hawk of the 760 lineup is among the top two performing 760s alongside ASUS's Striker, both are capable of matching the GTX670) which Johnathan Morin said is capable of running the game at Ultra as "90%" of the development team alleged ran GTX670s.
Has anyone else got a 2GB card to test these problems if you happen to have the game as well?
Optimal Settings
These are settings I've found to be the smoothest and closest to max settings.
Resolution: 1920x1080
GPU Max Buffered Frames: 2
Textures: High
Anti-Aliasing: Temporal SMAA (Higher AA applications lead to stuttering from my testing)
Level of Detail: Ultra
Shadows: High (Stutters on Ultra)
Reflections: Ultra
Ambient Occlusions HBAO+ Low
Motion Blur: On
Depth of Field: On
Water: Ultra
Shader: High
These settings are pretty close to the highest settings, the only settings affected are the Textures, Shadows and Ambient Occlusion, each by one notch, so If you're not so fussed about maxing the game but want something looking pretty good this could be a good option.
Screenshots
Footage
There might be minor hiccups in the recording, this is due to running shadowplay and possibly the stress on the hard drive.
337.81 Driver vs 337.88
I'm in the process of comparing 337.81 vs 337.88, it's unfinished as of now but will be updated.
Update: Added experience with new settings, these settings are not run in the benches below, the benches below are on the "Optimal Settings"
The runs consist of running from a Motel building to a pawn shop and exiting the pawnshop and looking across the street, this is performed whilst it is raining in-game.
337.81
Frames, Time (ms), Min, Max, Avg
3075, 73383, 31, 56, 41.903
FPS
49
48
54
51
46
47
50
48
50
52
40
37
33
36
49
47
37
37
33
33
33
33
32
36
38
34
35
37
36
39
40
44
45
40
40
41
39
39
37
37
36
43
45
45
47
48
45
50
50
47
45
41
44
44
40
42
42
42
43
43
40
40
43
43
43
40
42
43
40
38
40
46
45
2811, 68235, 30, 56, 41.196
FPS
49
51
55
51
48
49
49
50
52
49
37
34
34
49
51
40
40
35
31
32
32
34
30
35
37
33
36
36
38
37
38
37
46
39
38
38
36
35
34
35
35
43
43
44
46
49
44
47
46
45
41
42
42
42
40
42
42
41
43
40
41
40
40
43
43
43
42
43
2950, 71480, 30, 56, 41.270
FPS
50
53
52
45
47
49
48
48
52
41
37
35
38
46
41
37
39
33
32
33
32
31
33
33
33
33
35
36
36
39
39
41
41
39
39
41
39
39
36
38
38
44
45
46
48
49
47
49
50
49
49
43
38
38
36
42
44
43
44
42
42
41
42
43
42
42
42
39
38
40
45
3079, 74584, 29, 55, 41.282
FPS
49
49
52
54
52
47
48
49
50
50
50
40
33
31
38
47
37
40
34
30
31
31
31
31
33
33
34
34
38
36
38
37
38
42
39
39
39
37
37
36
38
37
46
43
44
48
48
45
47
49
41
42
44
43
43
41
42
43
43
41
44
41
42
43
41
43
43
41
42
42
43
41
41
44
337.88
3155, 73243, 32, 56, 43.076
FPS
49
51
55
52
45
49
47
49
52
51
40
36
36
44
51
42
40
37
32
34
34
34
34
37
37
34
40
43
38
39
44
49
40
40
41
41
40
40
39
39
43
44
45
47
48
50
45
51
50
47
47
42
45
43
42
44
44
43
43
45
43
43
44
45
43
43
43
44
44
39
40
45
45
2998, 71792, 29, 56, 41.760
FPS
49
51
55
53
48
48
48
49
51
49
40
34
34
46
53
41
39
34
30
31
32
31
31
33
33
35
40
42
35
38
37
36
39
46
42
39
39
38
37
37
37
44
46
45
49
49
46
48
49
48
39
42
40
41
42
42
42
41
41
42
41
42
43
44
43
43
43
40
40
42
46
3167, 74459, 26, 55, 42.533
FPS
49
50
53
52
42
47
49
48
46
53
26
36
34
42
50
44
36
37
32
34
34
32
34
36
33
40
41
38
40
38
42
42
48
43
43
40
40
40
39
38
38
39
41
47
47
49
49
47
49
49
49
48
42
45
46
44
43
44
44
43
44
44
44
44
44
40
43
44
41
37
39
45
46
47
2958, 69779, 31, 55, 42.391
FPS
51
55
46
46
46
50
51
53
41
33
36
49
48
35
40
36
32
33
34
31
36
36
36
37
43
39
41
42
39
39
40
41
40
39
38
37
37
35
44
46
46
47
49
45
50
51
50
47
50
46
44
40
44
43
43
43
44
42
43
44
44
41
44
44
43
43
39
40
44
Not much of a difference on my end, however I feel the game is averaging higher.
Other systems may have a different experience whether it be increased or decreased performance, I'll have to do some action and high-speed driving tests, I'm going to be experimenting with the settings again in the next few days, If I find anything interesting I'll be sure to update the thread.
Improvements!
Shadows and HBAO+
I am able to run Ultra Shadows and HBAO+ now, there's stuttering every now and again however, this could be a general problem with the game and may improve over patches and drivers.
Ultra Textures
Ultra Textures surprisingly runs alot smoother too! but it does still have it's stuttering issues but it's alot less severe, so i ran HBAO+ on low and shadows on high, basically the "Optimal Settings" again but with textures on Ultra, things have surely improved from my experience on my side, hopefully for others too.
Anti-Aliasing
I am able to apply MSAA 2X or TXAA 2X, no more stuttering caused directly by this it seems now.
Overall it seems this driver has had a positive impact on the game, the only real trouble is the Ultra Textures, however playing around with settings you might be able to get the game to run smoother with them, that and newer drivers and patches are likely to come and will hopefully improve the Watch_Dogs experience on Nvidia hardware, I hope the same for AMD too, their drivers are reportedly dropping tomorrow!
I'll try and find out if the GPU is being used more from these drivers too.
CPU Section
This section doesn't matter much with the graphics memory if you only came here for that, you can ignore this if you want, but if you've got a two cores or less than 4, or you're just generally interested in how this game uses the CPU you might find it useful.
Core Scaling
Dual Cores are not listed in the minimum requirements for this game, the requirements are shooting for a minimum of quad cores, and I think for Ultra 8 cores/threads.
I think an I3 would perform well in this game if it crosses the 5000 score mark but I haven't got one to test so I'm not entirely sure.
Dual core performance is pretty obvious below, Tri core and Quad core looks comparable, however I feel Quad core is more stable overall, they may not be of much use to anyone but I though I'd post them anyway to represent scaling between 2 to four cores.
An I3 4360 @3.70GHz scores 5,646
An I3 4340 @3.60GHz scores 5,260
This test will be ongoing and I will attempt to compare the scores and results to my performance with 4 cores.
I'm performing this test by locking two of my processing cores through the bios and leaving my processor overclocked @4GHz.
PerformanceTest 8.0 (Passmark)
CPU: AMD Phenom II X2 555 @4GHz
Cores: 2
CPU Mark - 2759
CPU - SingleThreaded 1361
Cores:3
CPU Mark - 4071
CPU - SingleThreaded 1380
Cores:4
CPU Mark - 5198
CPU - SingleThreaded 1378
Dual Core
Okay, so with two cores enabled the performance got hit hard, I'd say it was averaging at 20fps and was an un-smooth experience jumping up and down with stutter, this doesn't happen with 4 of my cores enabled. GPU utilization was ranging between 30-60 with perhaps an average in-between 45-50, the cores are practically completely maxed out.
(The voltage is high because I'm running the same voltage I used for Quad Core 4GHz)
However this is a Phenom II, I would think a sandy onwards clocked at 3.2 upwards would perform better, I'm looking at the 4340 and 4360 I mentioned earlier.
Tri Core
How one core works wonders!
Much more stable and playable than Dual core, it's running 30+ with utilization ranging between 67-99%, spending most of it's time in-between 75-85% however and pushing 30fps upwards.
Once again, the cores are maxing out, alongside high ram usage, the performance difference appears to be mild from 3 to four cores, it's not as massive as the jump from 2 to 3 surprisingly, however 4 cores may get higher max fps than 3 cores, I'll look at doing a fraps benchmark between all of them on or before Tuesday If I have time.
Quad Core
Core usage maxing out on 4 cores also, I'm going to upload a vid called "Action Scene" or something showing you what's happening in the scene with MSI Afterburner in the top left, but for now some screens of utilization.
GPU Utilization varies depending on the ongoing activity, in some areas it will be 80-99% and 35-45fps, often holding a stable 40, and in others it will be in-between 67-99% as activity and ranging between 30-40fps, and often 30fps when the CPU is hit hard.
Unlocked
(I'm unhappy with how I performed this test, so I'm going to be redoing it, ignore the Unlocked one)
It looks pretty messy, the frames are going 30-40+ and up and down, this is the CPU bottleneck taking effect, as with most open-world games they are often CPU-bound in various situations, one moment you could be holding a solid 40fps and the next your jumping between 30 to 40, for more powerful setups something between 50fps solid and falling to 35-45fps. I'd expect hexa and octa cores to yield much better results on the CPU side, especially Intel i5s and i7s.
Locked(35fps)
If you look between both graphs, you can see that the 35fps target is held successfully most of the time, this looks to be the sweet spot for processor, as if it it does dip it wont fall no more than 5 fps down to 30fps from my testing.
If you've got a Phenom II X4 or a similar performing processor, maybe a quad core piledriver you may find these results useful.
I wish I could do a better job at these CPU tests as between three to four cores the performance difference seems quite mild and this processor is aging, I'll have to do a fraps benchmark to compare better I think.
The GPU usage is not 99% so there's room for more frames if the CPU can deliver them, for those with tougher CPUs like I5s or i7s of Sandy to Haswell you're likely to have a CPU which can hold 35-40+ fps with a GTX670, like the 4670K for example which should be powerful enough. I did the CPU scaling to test performance between cores and usage and the game is scaling well from 2 to four cores.
Unfortunately I'm CPU limited to between 35-40fps stable but this was a test of CPU usage and core scaling on my "Optimal" settings.
However, for those 2500Ks-4670Ks I would expect a solid 40fps, as in a lot of cases my GPU isn't working at 99%, with the extra grunt of those processors I think they'd be able to easily pull off 40 fps stable with a comparable GPU, like a GTX670
Update: I may not be so CPU limited after-all if more-powerful CPUs are have trouble maxing their GPU most of the time too, OC'd i5 280X/7970 setups and 780 setups, this shows that this may just be a problem with the game itself and not solely the CPU, it seems Watch Dog's scaling with hardware can be unpredictable at times.
This was mostly intended to be a post about performance with 2GB vram but I decided I might as-well demonstrate how this game uses 4 cores and how it scales with them.
I hope the community find this useful and beneficial, this may give those with dual core chips, quad cores and similar performing graphics cards or processors to me an idea of what to expect from Watch Dogs on PC, In my opinion this is one of the best performing Ubisoft titles and it's one of the only, if not the only which scales between 4-6 cores as me and other OCN members have reported, not entirely sure about 8.
-Edit: I take this back, seems I'm one of the lucky few that can get the game to launch and not crash every two minutes, people have reported endless stuttering even when altering graphical settings, It's not looking too good for this game, AC3 was worse for me on the performance side, I ran the entire game in the 20s when I had a 6850 no matter the graphical settings, but If people can't even get this game to launch or are having problems with Uplay then this may just be worse.
Update: Oddly tougher hardware is having trouble keeping their frames up, along with GPU utilization.
There's something very wrong here then if tougher systems are brute forcing it with overclocked i5s, i7s 780s and 290s, at first I thought this game was a good performer but it seems different configurations have different troubles if the GPU is being constantly under utilized and stuttering is a regular occurrence on various setups, I hope they get a hold of this.
The alleged 2GB problems may worry a few, I think give it a few days for a patch or two and a driver from Nvidia before panicking, as even the 3GB cards have been said that they can get into some trouble with some applications of AA.
Update: It seems various setups are encountering different troubles, even 2500Ks and 780s are having stuttering problems, low GPU usage followed by frames.
#3 ·
Got my copy from Ubishop Saturday morning.
Didnt think it would let you play it before hand but Ill give it a try.
#6 ·
Good work and the screens make the game look pretty good, though it's the day time shots that are always very mehtastic.
#7 ·
are all of those screenshots using high textures ? if yes, can you post the ultra textures ss, so that we can spot the differences ?
#10 ·
Here's some shots I just took... Most have FPS in corners.
Settings: 1440p, Ultra (maxed everything), 2x MSAA. 3GB of VRAM. SLI enabled. I do experience 1-3 frames of chops every now and then, especially in high density areas, but it's totally playable.
#11 ·
Originally Posted by Wirerat View Post
so we have to post proof of purchase to talk about a game now?
if it's an early copy I would think yes, heck OperationSports has this policy to avoid getting in trouble.
Edit: Too clarify their rule is you have to post proof you actually own the game by posting your games case and game in the case with your username before you can discuss the game in their impressions thread. This only applies when it's an early copy (meaning the person got it early) as to avoid trouble with devs and publishers.
#14 ·
Originally Posted by XT-107 View Post
lol , if you have to look and compare side by side for difference then what's the point if it's ultra or high .
I'm pretty sure he just wants to know the difference between the two settings to know what you'll be missing.
I will say this: Screenshots don't do this game justice. Even my 10MB uncompressed images linked above look quite a bit worse than actually playing.
#15 ·
Haha.
Okay here's some close ups, as in most games if you go really close you'll be able to make the textures look poorer than from when viewed further away.
High
Ultra
Images might decrease in quality because I've uploaded them here, but we'll see how they look.
Let's play... Spot the difference!
Only thing increased was textures to Ultra.
Got a couple more so I'll edit this post.
#16 ·
exactly
Originally Posted by TopicClocker View Post
Haha.
thank you, I can easily spot it
not much of performance hit going from high to ultra based on your ss, I wonder if it's the same in a heavily crowded area.
That is some hefty memory usage on ultra & high, does your GPU starting to choke at that mem usage ?
#17 ·
Originally Posted by Luciferxy View Post
exactly
It's a slideshow basically on Ultra textures. On high it's alright.
#18 ·
The scarf and the hood are the only ones which have difference on Ultra.
Is there Physx and Gameworks settings? Is there anything of these technologies in the game? Did you leave motion blur on maybe turning it off will improve the performance?
#19 ·
I did test just now. 780ti Matrix at 1440p with everything maxed out except no AA. Everything was fine fps was rocking until.. car chase. Frame Latency went off the roof. the Texture amount which hits the VRAM used... seriously decided depending on the action sequence. Low action u wont feel it.
Car chase, gun shooting etc..
Reduced the Texture from ultra and it was fine but still not as smooth as running on a titan black. Not even close.
Its not the other settings thats really is the issue for 780ti but the texture with the limited mem.
Here is a video of 2560x1080p with everything maxed out with Rainrender on and FX PC at 4x MSAA
if 780ti had 4gb of mem.. it would have owned this game. only other option is Ubi have some kind of option like VT compress etc like wolfy did.
#21 ·
I probably need to post other shots than just close ups, I'll see what i can do.
No Physx to my knowledge, what do you mean by Gameworks, It's Nvidia exclusive isn't it? I remember reading about the Unreal Engine 4 having Gameworks support from Nvidia.
#22 ·
I gave it a go and it seems the game is heavily CPU bound in some places. Especially when driving around intersections the fps could drop <30 regardless of min/ultra settings. And this was with my 4.4 GHz 2500K. The CPU utilization hovers between 70-100% with all cores. It would certainly be interesting to see some CPU benches with this game. They do recommend 8-core CPUs so maybe that would help alleviate the bottlenecking. Level of Detail setting seems to be pretty much the only thing that will drop cpu usage, the rest are more or less GPU intensive settings. Hopefully AMD will release a working CF profile for this soon, since one 280X doesn't seem to be enough even for 1080p. AC IV had similar troubles actually but CF support definetely helped even though it seemed at first like the game was bottlenecking because of the CPU.
#23 ·
It's nice to see a game properly stressing CPU cores, I wonder how 2600Ks, six cores and eight cores would perform, from both Intel and AMD.
And your 2500K is at 4.4GHz? wow that's surprising to see the frame-rate dropping still, I expect a driver or two and some patches to help smooth this game out, but currently it looks like you need alot of video ram to run this game smoothly at higher settings, the 290 owners seem to fair better than the 780s
I think I'm gonna give dual core a try at 4GHz, maybe today.
This is for those who have less than 4 cores and to see how this game scales from two to four processor cores.
#24 ·
Please do that I'll be waiting for it. There are some videos on the YT with i3s running at medium. Seems like it can start with 2 cores or maybe is it because hyper-threading.
#26 ·
In a lot of videos the game character is killing cops, etc. Is it necessary? Can you play like Splinter Cell by making your way through by not getting yourself seen?
Hmm I haven't played too much of the story but from the missions I tried you're often given a "takedown" objective so you can either shoot them down or get up close to do a melee.
I've played stealthy a few times and it can work but I think there may be a few missions where you are required to take down or kill a target, not 100% certain however.
There's distractions you can use to lure the opponents so you can play stealthy if you want.
