Hello. Im sick of using windows, because its bloated as hell. So I want to know, which version of linux is great for beginners? I want to run it off a flash drive, and I would like it to be fast. Thanks
Originally Posted by goonies ![]() I always had good hardware support coming straight off the gui install with Fedora Core and Mandrake back in the day which I believe now is called mandriva. Just try a few of the more popular ones on that distrowatch site, or if you're really daring make your own from scratch www.linuxfromscratch.org. don't forget to try out compiz desktop effects might be called something different now really neat stuff windows aero doesn't even come near to what compiz does. well with ati i'm not sure how hard it is going to be to get compiz to work i had a hell of a time getting it to work on my ati card, but finally was able to with help from the forums for fedora. |
Originally Posted by hooah212002 ![]() Just create a new partition.....(Linux is far more friendly to Windows than the other way around). |
