I thought the whole point of an ITX case was to build a small but powerful system. The Prodigy measures 250 x 404 x 359mm, which makes it larger than most micro-ATX cases. The Silverstone TJ08-E, for example, measures 210mm x 374mm x 385mm.
In terms of volume, then, the TJ08-E is actually 17% smaller than the Prodigy. But the TJ08-E can fit an SLI setup and a micro-ATX board.
So here is my question. What's the point of an ITX case like the Prodigy if there are great micro-ATX cases that are smaller?
Prodigy interior:
TJ08-E Interior with SLI setup:
Prodigy interior:
