One of the best mid sized air coolers on the market.
review by
maiky
Reason why I bought this cooler over any of the closed loop water-coolers is due to a faulty H80 that I had purchased not too long ago (not taking anything away from Corsair, just my personal experience). I have always used air cooling over water since it's cheaper and easier to maintain/clean. I looked at many air-coolers prior to purchasing this one and it came down to the 212 EVO/NH-D14 and this cooler. The EVO is a nice cooler, the chrome/aluminum on the other hand is old school looking and the Noctua is just to big for my taste. This cooler comes in 3rd place when it comes to performance but since it is the smallest out of all 3 and it's black it was a no-brainer. The color of the cooler was a major factor, I wanted to make sure it would blend well with both the mobo tray and the mobo itself. The fan the comes with this cooler is top-notch, at low speeds you cannot hear anything, at 2200RPM it becomes audible but nothing to worry about.
The installation on the other hand is a pain unless you are going to use the AMD backplate. For intel users I recommend you-tubing the installation (also make sure you install the rubber fan grommets prior to installation or you will be forced to remove the cooler once you are done). The back-plate that comes with this cooler leaves much to be desired, it's plastic instead of steel/carbon. For $49.99 you would expect better. Regardless of the back-plate the end result is phenomenal taking into consideration that it only has 3 heat-pipes compared to other coolers that use 4 and above.
Here are a few numbers I would like to share :
i5 2500k @ 4.5GHz (1.3v) idle hovers between 28-34c (depending on ambient temp).
i5 2500k @ 4.5GHz (1.3v) LOAD (large FFT's) hovers between 66-74c (depending on ambient temp).
i5 2500k @ 1600MHz (.968v) hovers between 24-28c (depending on ambient temp).
My ambient temp normally is between 70-78F, all these tests were done using a Corsair 600T.
When it comes to gaming @ 4.5Ghz it normally sits around 62-65F (@ 4.2Ghz or lower it sits around 55c or lower).
In all this cooler was a great buy, I have no complaints other than the back-plate and the instructions. If you want a nice looking air cooler that rivals most top end coolers and wont break the bank then consider the Dark Knight II, you will not be disappointed.
Pros | Cons |
Efficient cooling, looks, can do push pull if needed, does not interfere with tall ram sinks. | Plastic backplate, installation. |
Ratings
