Why use water?
884 views 19 replies 15 participants last post by  Kriegen
#1 ·
Water is very poor at absorbing heat and transferring heat. Water also retains heat very well and is poor and cooling down or heating up. Why not use a liquid thats just as visquos and that could take heat away faster and cool down faster. I've been wondering this for some time can someone tell me why not ?
#7 ·
I'm using 90% distilled water. If you could inform us of a liquid that is just as visquos as water is feel free to let us know.
#11 ·
coolant in cars IS 50% water... but the other 50% is a bit too corrosive and toxic to use inside of a PC -- typically a great coolant mix for a pc loop is 5-10% antifreeze (mainly xx-glycol/additives) diluted in 90-95% pure distilled water.
Water has a relatively high heat of vaporization, high surface tension, wide availability, and is harmless to humans (and in its purest form) harmless to electronics as well. This is why we use it.
#12 ·
"watercooling" allows the heat to dissipate faster as the channels or fins in the waterblock transfer the heat to the water, which lead trough tubes and is cooled down by the radiator allowing higher voltage and a higher OC (on a chip with potential to clock higher)
just wondering......, would hydraulic oil work? (cancels out the shortcircuit caused by water)
#15 ·
Specific heat of oil is not as good as water. It cannot store and transport as much heat as water.
#16 ·
Water is very good at absorbing heat with such a high specific heat value. That means it absorb a lot energy. You do not want a liquid that evaporates or expands when heated with a 200-300w. Who cares if the heat is in the water? As long as the heat is not in your processor or components.
#18 ·
Originally Posted by NuclearCrap View Post
Who said we use water?
Originally Posted by BigpoppaFrary View Post
"water Cooling"
Lmao
But seriously, water obviously works good... or people here wouldn't be using pure distilled water with that other stuff added in, vinegar, iodine or w/e you kids now adays in.
And seems to me a lot of people use coolants and bottled stuff, like that FluidXP or w/e.
#19 ·
#20 ·
The stuff added to cars is used to change the boiling and freezing point of water and actually reduces the waters ability to transfer heat
