Are some Air coolers too heavy?
6.1K views 48 replies 30 participants last post by  oldcompgeek
#1 ·
Just curious if the weight of the 212+ (or other 120mm similar coolers) bother anyone else? I looked up some spec sheets on a few motherboards and some say a max of 400g weight for the cooler. Do the backplate's that come with aftermarket coolers compensate beyond what the motherboards max is? It's just one of those things that bugs me to the point of going with a 92mm cooler like this. Almost half the weight of the 212+ and from reviews, very similar results.
I'm comfortably sitting at 4.6Ghz with my 2500K and never really hitting 50c under normal "gaming" load. In the BIOS I have the fan settings to quiet instead of the more aggressive settings as well. Would it be okay to go with a smaller cooler like a 92mm heatpipe style rather than my big heavy 212+?
The reason I bring this up is because at work I see a ton of boards that have been totally warped into a "bowl" shape after only a few years of use. Granted these boards are basic Intel boards with no backplate at all but I still see what some weight and pressure can do to a PCB after some use.
Edit: The 212+ is 600 some grams in weight.
#2 ·
My N520 weighs 668 grams. I was wondering the same thing when i was putting it in; felt like the mobo was going to break. I have had it in my PC for almost a year now, so doesn't seem to be a problem.
Edit: had the board out a few weeks ago and it wasn't bent at all.
#3 ·
You could always use some zipties and ghetto-rig it to secure it to some other part of your case.
I've used an Arctic Cooler Freezer 64 Pro on my previous AM3 build for a year and a half, didn't notice any mobo warping. I imagine the screws holding it in would be more stressed than the motherboard.
#6 ·
People are too paranoid about the weight of CPU coolers. I've got a Silver Arrow, with 3 fans on it, heavy as hell but its been on my PC for over a year now no issues.
#7 ·
I've had my silver arrow attached with super heavy server fans for over six months, which really added some heft. Happy to report no warping yet. I am thinking that prolonged use without the mobo being screwed into the case could allow warping. But, just like back plates of graphics cards, the case should prevent that.
#8 ·
yeah i think the majority of the stress is on the case actually.
If you think about it, the screws are what the heatsinks are technically putting stress on, which
in turn is putting stress much more so on the case rather than the mobo. Although this doesn't apply
to those intel push pin heatsinks, which from what i've experience seens to put the most stress i've ever seen
it bent one of my boards... i will never use again.
#10 ·
I think so, always wondered if my 847 gram coolermaster n620 was the cause of a motherboard failure I experienced. In addition to weight, it was also quite tall, thus putting more strain on the motherboard.
With the advantages that the all in one watercooling solutons currently offer, I will never buy another large air cooling HSF.
Here the n 620 - http://www.newegg.com/Product/Product.aspx?Item=N82E16835103066
#11 ·
You are perfectly fine with your 212+ ...
My TRUE weighs in at 790gr and it has two kaze 3k fans on it ... that's a total of 1240gr .. 1.2 kilos and I also did the washer mod. Been running like this for >3 years and its perfectly fine. (Mobo is a little warped but nothing to worry about).
#12 ·
#14 ·
Thanks all for the reassurance... I feel better about it now but I think this will just push me toward an entry level water cooling option in the future. We had an alienware that was about a year old in the shop today and I really liked the way it looked. How are the entry level water coolers compared to a 212+?
Edit: The alienware had a H100 "like" water cooler.
#15 ·
#17 ·
I wouldn't worry about 600 grams, the only cooler that I have ever heard about that actually could damage your motherboard was the Thermalright TRUE Copper , weighed in at 1900 grams.
I have the Thermalright true (non copper one), and that weighs 790grams and I have had no problems with the wieght, even when I move my pc around. Thats not including the two 120mm fans I have attached to it to.
Just about all decent coolers will come with a backplate that will spread the weight out a bit over the board and prevent warping, also be sure to not over tighten the bolts as that can bend the board a bit.
#18 ·
My FRIO weighs 1042 g
#19 ·
Originally Posted by Jayjr1105 View Post
Thanks for the suggestion but I don't think I'll be going that high end. Maybe something like this. I'm not looking to go much higher than 4.6 and my temps are already pretty good.
that or the corsair h80 - h100 will do the trick for 4.6GHz on a closed loop.. even higher
#20 ·
Honestly, unless you plan on dropping it, I wouldn't even worry about ~2000+ grams.
#21 ·
The 212+ is a lightweight.
All the good coolers use a backplate and make a motherboard sandwich, which is plenty stiff. And as TH3 original noted, the stress is taken up by the mounting screws, especially the ones on the top edge of the mb.
#23 ·
normally heat sinks have back plates, with the back plates it will support the heat sink just fine. motherboards are sturdy stuff, they don't break as easily as you think. its not super fragile material, I have abused my old H55 motherboard so much that simple heat sink weight breaking it would seem silly. I have seen people wash their motherboards in the dishwasher and different things and the mobo still works just fine. if you had a spare mobo, you could try and snap it in half, it takes quite a bit of effort, it will bend easily, but to break it takes more effort than just heat sink weight + gravity
#24 ·
The Tuniq Tower would sag on some people's boards. Depends on the quality of PCB I would figure. My board is flexed like a rainbow lol. Heard some minor cracking when I tightened the board down to the case though haha. It's working fine.
#25 ·
had my true copper for around 18 months and my mobo is very clearly warped, wonderful cooler but 1.9kg without fans is silly.
#26 ·
I said it first D:
why does nobody pay attention to me D:
