My QCK heavy is getting old and I'm trying to figure out what their controlled equivalent is but they seem pricey. Anybody have experience with them? Worth it or no?
I have a Zero Mid, in my opinion its not worth it just due to the fact it has a higher difference in x/y glide than my QcK Heavy does, and its a massive dust magnet
Also, it wont stick on my table properly, even if i put a bit of water there, when it dries up it swooshes around
This is perfect, thanks!No experience with it, but on the same boat as you
Considerable yet they are expensive and the corners are not stitched ~ strongly unsure
https://docs.google.com/spreadsheets/d/1RAnmZxDNduaGV8kB-GCvZ0MO6d9-0j9jmrU2f8dp0Ww/edit#gid=0
this might help you for alternatives
I own the Goliathus Control but it's surface could be faster, although good enough
Soo i keep my eyes on the Hayate Otsu, same as the Endorphy Cordura Speed
- although something soft texture like is nice for the wrist
If you scroll down in the doc, you'll find an old but well written review about the Artisan's
Focus more on the rated list tho and find first something comparable you optimally can try somewhere locally
~ well it would be great if you know already what you like, but still
EDIT:
Be sure to also check the Longevity & Pricing Tab
Washable is important unless you have a glass or fully metal base - mousepad
And so also coating longevity after X months of usage
This is definitely the appeal in Artisan pads for me as well, they are all very unique and interesting surfaces and the quality is seriously good and something I can appreciate. I think I have 7 Artisan pads, and it's been enjoyable trying them all. I think the Raiden XSOFT is my favorite. The XSOFT option is nice and cushiony, I've never used anything else quite like it.Quality wise the Artisan pads are absolutely worth it, and if you are one for supporting small companies/the little guy over big companies producing things in China and turning a profit, then yeah, I would buy from them. Best stitching by far (below the pad, so it never interferes). Surfaces are all unique in their own ways with interesting friction properties and concepts.
Artisan link is very oldhttps://docs.google.com/spreadsheets/d/1RAnmZxDNduaGV8kB-GCvZ0MO6d9-0j9jmrU2f8dp0Ww/edit#gid=0
Mousepad Master Sheet by Hoya
Out of curiosity, what did you end up with?I've had 3 artisans over the years, I didn't stick to using any of them.
