10,441 - 10,460 of 13,940 Posts
Just wanted to interject real quickly that just for ****s and giggles I copied these exact settings for my kit (same exact kit as yours) and it worked flawlessly. I'm getting even better latency now than you have in that screenshot. I'm using c8h hero non-wifi w/ 5800x. Thanks so much for sharing :)
You (and Gertrude) are welcome ! :)
Power Reporting Deviation (Accuracy) issues that were seen in HWiNFO64 with all previous BIOS versions seem to have been fixed with the 4002 beta BIOS (as I saw mentioned somewhere else). It is no longer dipping below 90%, have only tested for 35 minutes so far, but by now I would have usually dipped below 90% already and into the 70% to 80% region.
I will report back and strikethrough this comment if it does end up dipping as usual.
EDIT: I am confident it is 100% resolved. It has been 10+ hours pretty much.
You can disable it in the BIOS and then uninstall and disable it from boot services. You'll never see it again.
I have been using Windows 11 for months.
I know but i need it to sync the Lightning of the Board,the Asus 3070EKWB and Ram.
I wish there still was a Standalone Aura Software or some Option in Bios to change some simple Colors...
Every Mainboard i had in the past few Years had this even the cheap Asrock x370 and with the Gigabyte Master z390 we had at least a modded Bios for RGB.
Or they could implement Aura in AI Suite which works great for Fan and Pump control without using much Ressources
20Minutes and two Restarts!
that was needed to uninstall Armoury Crate the last Time with the Uninstall Tool lol
Why not use aura sync standalone? ASUS Aura: Campaigns
Hello Guys. So I bought Arctic Freezer 2 360mm radiator. I am testing it, but I found something interesting in manual. For Ryzen 3000/5000 it is recommended to use an offset. Do you have it set..? Have you tested..? Do you have some results..? Is if better to cover whole CPU or just partialy with offset..? Any compare results..?
And also, which CPU temps I should check..? CPU Package, or CPU..? I usually look at Asus AI Suite 3 and temps are completely different. Thank you
PS.: Result from CPU-Z bench.. It seems to be really low. Isn't it..?
I use offset mounting on my Arctic Liquid Freezer II 280 and the temperature, compared to normal mounting, is 5-6 degrees lower under load. Very worth it imho.
Also, the Arctic Liquid Freezer II 360 is a beast.
There are also solutions such as OpenRGB and SignalRGB if you haven't already checked those out. :)
I agree that some simple RGB settings in the BIOS would be great though.
Reactions: Anulu
can you share with me your profile of I think we have the same hardware so I can use it as a guide. :unsure:
I am still using this BIOS configuration as per post #9929 . Obviously you will have to change ram timings/pbo curve/peripherals depending on your hardware and usage. Also, I am on Win11.
I control RPM with AI Suite 3. CPU FAN (three Arctic cooling fans) speed is low I would say.. I tested OCCT Linpack and CPU Package is about 65°.. Isn't it too much..?I am not sure on which temp I should focus..? CPU or CPU package..?
Yesterday I saw blue death for first time when I was using the AI Suite3, I will try to reinstall AI Suite completely and will create new FAN profiles.
Any suggestions to air flow? I have Radiator in front and three fans blowing air TO the case through radiator and there is one Noctua in back side, blowing how air from case out of the case. As well as 2 Silentium FANs on top, blowing air out of the case. back and top, there are another three. Any suggestion to improve CPU temps..?
Thanks for that Information,both Programms are intersting.I couldnt change Brightness with Asus Aura but with SignalRGB its possible :oops:
For System Performance OpenRGB seems to be better and it doesnt need to run in the Background.
This old standalone Version does not work with my Mainboard,tested with Win11&Win10
This new 0602(for Extreme) is arguably the worst boosting bios so far, however it is faster in certain tasks like HTML and text compression which is important for the desktop experience. The "bad" boost is most likely intended to enhance stability, as self rebooting PC:s has plagued the 5-series and the high boost behavior is probably why. I take stability over a slight higher score any day, so I'm fine.
It used to boost to 5025MHz with the same settings, now it's 4900MHz, so 125MHz lower. But probably more stable.
Quick run with PBO and 1900 1:1
Latency is worse, once used to be repeatedly 55ns, but that would be because the lower peak frequency.
edit. YES, it IS more stable. Before I never got WHEA except during heavy gaming, just the occasional no reboot, but now I gamed for a couple of hours and not a single WHEA. It is not conclusive, but looks promising.
Reactions: GRABibus and J7SC
My bad, sorry, I thought its 1.07.84 version I`m using, with that v2.2 I couldn`t sync my gskill ram... I`m using 1.07.84 right now with the dark hero (before that I had a B550 F) and it works ok, if you want to give it another try I can give you a link for it.
No Problem,where did yu get that 1.07.84 Version? I can try it on my Dual Boot Win10 Partition
With Armoury Crate Aura i had to install the Gskill Tool and then deactivate from Autostart to get Control in Aura.
With Open RGB i can change the colors of all Devices including the NVME Extension Card form the CH8 Impact and the 3070EKWB Cable connected to the Header.
The Lightning is useful to distract from what i have done to that poor H200i Case :ROFLMAO:
hey if it works :ROFLMAO: ...here is a link for the 1.07.84 : 185.1 MB file on MEGA
I got it from the Asus site, from where I initially pointed you but didn`t really pay attention to which version it was, I just assumed it was the same I had, but apparently they pulled it down for some reason :unsure:
Am I the only one who doesn't prefer RGB. :D I disabled also small LEDs on board, because it disturbed me a lot.
Nope, you are not, I was the same but it slowly started to grow on me :LOL: ...plus it is nice to have it on rainbow puke sometimes :ROFLMAO:
I'm not a great friend of RGB, but it is becoming more and more difficult to find peripherals that haven't succumbed to that trend...so I just set everything to my favourite blue :cool: .
...system on the left runs it all via Asus Armory Crate, system on the right uses the older free-standing Aura, plus GSkill's little app which I unload after boot-up (RAM colour stays locked)
when do you test 4002 beta for us ? 😜
