ASUS VE247H 23.6-Inch 1920x1080 LED Monitor
2.2K views 3 replies 4 participants last post by  Overclock Reviews
#1 ·
Description:
VE247H LED - 23.6" 1920x1080
Details:
DetailValue
BindingElectronics
BrandAsus
EAN0610839331574
FeatureMercury Free LED backlit panel
Weight9.7 pounds
LabelAsus
List Price$202.91
ManufacturerAsus
ModelVE247H
MPNVE247H
Package Quantity1
Product GroupPersonal Computer
Product Type NameMONITOR
PublisherAsus
SKUVE247H
StudioAsus
TitleASUS VE247H 23.6-Inch 1920x1080 LED Monitor
UPC610839331574
#2 ·
Asus ve247h
review by banging34hzs
First off I would like to say this is a great monitor. I paid $145 usd and got my $10 MIR. This monitor has been great for playing what games I do play, (bf3, C&C 4, SupCom 2, Mafia, DS 1&2) the 2ms response time is great and overall picture quality is great. Side note do not crank up the LED back light on a fps with taclights or flashbangs it will blind you.
As fir the stand being small, when under intense gaming ( 64 man conquest on metro ) if i hit my table roughly i get a odd ripple effect to the left of the ASUS sign on bottom of monitor
Over all I would recommend this monitor to anyone who is looking for a budget 24" monitor.
ProsCons
price for size, 2Ms, 1920x1080stand seems small for size
Ratings
Overall5
#4 ·
Vivid Awesomeness in a Screen
review by kishagi
This monitor is quite something! I got it at $150 CDN on sale last year and it really hasn't let me down since. The screen does need some calibration out of the box but other than that there is no real problem, well other than the 60hz refresh rate. Although Newegg shows specifications for a higher refresh rate, my limited knowlegde has yet to draw them out. According to Newegg the refresh rates are as follows:
Horizontal Refresh Rate - 30 - 83 KHz
Vertical Refresh Rate - 50 - 76 Hz
I went out to buy this monitor thinking that the response time was the refresh rate at 2ms, would have been awesome I believe. Although I was wrong, the 2ms response time eliminates any ghosting that i could possibly see. The picture has always been very vivid and sharp and completely out does every monitor that Ive ever used.
The screen is matte so you dont see any reflections in the screen which makes watching movies and gaming a lot more visually stimulating. At a later point, I attached my PS2 using a Component to HDMI converter and played Persona 3 FES. The visuals were good but reminded me of the PS3's emulation of PS2 and PSOne Games, the edges of characters seemed jagged but since this monitor also has a 4:8 Aspect ratio, playing older console games on it is easy on the eyes.
I would recommend this monitor to anyone who is on a budget but wants a good solid quality screen.
ProsCons
Bright, 2ms, Multiple inputs, Full HD, HDCP support60Hz refresh rate
Ratings
Overall4
