Best Chasis Manufacturer?
3K views 53 replies 38 participants last post by  g_ablett
#1 ·
What are your top picks for computer chasis?
#11 ·
Antec/Lian-Li/Coolmaster
#13 ·
Originally Posted by P£P§!
Lian-Li, Antec, Silverstone, Coolermaster maybe
Ditto. No one beats Lian Li in quality, but their looks aren't for everyone.
#16 ·
Originally Posted by marcus000 View Post
1) Lian Li A70/ A71
2) Lian Li V2000/V2010
3) Silverstone TJ07
4) Silverstone TJ09/10
Concur. And to anyone who says CoolerMaster, you must be joking right? The last good case that CoolerMaster made was their Praetorian. Nothing since is even close to "quality".
#17 ·
coolermaster, silverstone.
lian-li has the quality but quite frankly I don't see what the hype (or crazy price) is about. In many examples, they simple do not have the air cooling potential of much less expensive cases.
antec is a mixed bag. the p180 series is quality crafted and quiet but maximized air cooling? not so much. the 900 is great air cooling but terrible wire management, the 1200 a step in the right direction.
silverstone again is hyped but after briefly owning a temjin tj-09, I won't be trying another any time soon. It was well built but despite claims (and reviews that I made the mistake of trusting), the actual thermals of the case were much worse than a cheaper coolermaster I owned.
In my opinion, if air cooling is the plan, then coolermaster wins. the 690 is cheap and yet well designed, the cosmos s, and stacker 830 series are phenomenal (with a few quirks, the cosmos s will not fit a tower cooler above a certain height and the stacker 830 has very poor wire management).
I guess you could add select models from thermaltake, (the armor for example)
#18 ·
Coming from a lian-li owner?
I am willing to match my old stacker 830 internal ambients, cpu, chipset and gpu temps against any lian li and win. the cosmos S is even better.
if we are talking water cooling, then it doesn't matter as much.
To clarify, I've also owned a Lian-LI V2000. (I change cases alot....)
I stand by my opinion of the silverstone TJ-09. I returned it after 3 days because my SLI gpu temps were over 10C higher than with the stacker 830 under load with the exact same build.
and the stacker 830 was $100 cheaper than the silverstone was.
the cosmos S I now how is even better.
#23 ·
On my desk, I have an Antec P180 and a custom Silverstone TJ-04. The way the P180 is design is flawed, but in numerous revisions have fixed most of the problems. The TJ-04 is a little tough to work with, and will probably find its new home in the trash can.
#26 ·
Originally Posted by dasparx
Good ole' oldschool chieftec~!
Yeah... they make some damn sturdy big towers, design would just need updating.
Lian Li seems to be one aiming to quality and no nonsense functionality most consistently and haven't yet noticed review which would have chided their general built quality. But price is definitely from high to very high and some old fashioned points of design are both good and bad.
Antec has wide variety of cases, mostly on cheaper end of scale and some bigger cases aren't as big as they try to be.
Coolermaster has also lot of different priced cases, Stacker is probably the most widely copied big case.
Silverstone again makes big variety of case with simplified style, emphasis looks to be in very small cases, some quite expensive cases have bad design solutions.
As for Thermaltra... take, antithesis of Lian Li, bling raised to cube of thousand.
