[build log] Antec P280 gets a makeover
5.2K views 20 replies 8 participants last post by  Lutro0
#1 ·
My P280 has been a great case for the last 2 years or so. Plenty of room for air cooling or an AIO and provided enough space to do a small loop but the case was obviously not designed with water cooling in mind. I intend to fix that. Yes, i cold go spend ~$300 or so buy a 900d or something else that is already designed to accommodate larger loops and radiators but where's the fun in that? If I remember correctly i bought my P280 on sale for $100 so i feel i already gave a great case with very little invested; why not get the most out of that $100? Follow along with me and let's see what I can make out of this thing.
My goal is to make room on the top panel to hold a 360mm radiator in a push/pull config and move my current 240mm radiator to the front of the case in a push/pull config which is currently being blocked by drive bays. I don't plan on keeping the 5.5 drive bays either. Time to get rid of those annoying things!
Drill baby drill!
Many rivets later
Mother board tray removed
I feel like a serial killer dismembering a body at this point
Now it's time to make room for that 360mm radiator on the top panel. Bust out the dremel.
Four dremel cutting wheels and a lot of sparks later
Now I'm going to make the new piece for the top panel out of acrylic/plexi whatever it is, I had it lying around and it's stiff as hell.
Ignore my math scribbles
Done measuring and I've cut my section away from the larger sheet
Gotta be careful drilling through this stuff. Got to slow down the bit just before it goes through to the other side
Hole saw time
Sanded and primed
Lets see how it fits
Not bad. After a little u channel molding, some modders mesh and paint it will look like it came from the factory that way.
Well that's all for tonight. I'll drill the holes to attach the acrylic to the top panel tomorrow and start sanding the case down in prep for a paint job. I'm still trying to decide If i want to go through the trouble of painting it white or sticking with a satin black look and what would be best for the build that will go inside this case when it's completed. Input would be appreciated.
#4 ·
Sorry but I've been working ten hour days and it turns out covering a black case in white primer takes a long time and a whole lot of primer. The case is close to being ready to be put back together. Meanwhile I had a bunch of stuff I ordered arrived today so I got to work on some other aspects of the build while the clear coat dried on the case.
New today:
XSPC 360mm EX radiator
Primochill hardline compression fittings 1/2"
Primochill clear acrylic tubing 1/2"
Corsair SP120 high static pressure fans x 11
XSPC Photon D5 res/pump combo
XSPX Photon D5 aluminum mount ring
Mayhem X-1 oil black concentrate
What's old:
XSPC 240mm radiator
XSPC ray storm CPU block
XSPC GTX Titan/780/780ti block
Intel i5 4670k
PNY GTX 780
ASRock Z87 extreme 4 mobo
Corsair vengeance 16gb 1600mhz
Corsair RM750 watt PSU
Painting the Primochill fittings and the mobo heat sinks gold
Here they are dried and put back on the mobo
Got a few fans done tonight as well
Tomorrow night will be spent cutting a new mobo mount and doing some more fan painting.
Thanks for checking out my stuff.
#6 ·
Thanks man, I had no idea what I was getting into lol. I totally see why so many people abandon their mods. The only thing stopping me from riveting the case back together is that for some reason, the entire inner rear panel has a slight pink tint to it for some bizarre reason. Now I have to sand it down again and use a gray primer instead of white to cover whatever is causing that pink tint and then repainting and clear coating it all over again. Still have to cut a piece of plexi to make the new mobo tray/res mount which can't happen until the case gets the riveted and I can take measurements.
Fun stuffs
#7 ·
Project is getting pushed back further. The inner rear panel is giving me a migraine. I sanded down the original white primer that had a pink tinge to it and washed the piece and left it to dry last night. Tonight, I sprayed it down with the grey primer and it immediately started to crinkle. I'm not getting good adhesion for whatever reason. Luckily the owner of a local car customizing shop owes me a favor and is going to sand blast it down to the bare metal for me. I'll be back with updates in a couple days.
#10 ·
slowly but surely this project is coming together. i finally got around to cutting the new mobo tray and am drilling the mount holes right now. i had to drop the motherboard down farther towards the bottom of the case to make room for the push/pull config on the top panel. heres a shot i took while doing a quick check to make sure everything is going to fit right. nothing is bolted down and the clear piece of plexi that everything is sitting on will be painted white to match the case.
#11 ·
I accidentally snapped my acrylic mobo tray I had cut the other day so here I am remeasuring for a new one. I'm glad actually since I think this second one came out a little better.
All measured, cut and drilled. Now I just need to cut the hole for the CPU backplate and it will be ready to be sanded and painted white.
As I've said before I had to mount the mobo lower in the case to accommodate the top 360 rad with push/pull. Basically the IO ports get pushed down into the PCI slots so a little dremel action was required. Supper happy how it came out. I was really just winging it on this part.
Of course lowing the mobo now leaves a gap where the top of the IO panel used to be. Here I cut a small piece of plexi to fill it in. I'll be sanding this piece down and painting it white. It fits in so snug I won't even have to glue it
Here's the PCI covers I bought to replace the stock ones that come with the case. They are of course painted gold to match my theme.
Here they are in the case
Now I had to cut a couple PCI covers to fit the two slots the mobo has pushed into. I cut an extra one to make sure it would fit.
Perfect fit. This whole part of the project came out great.
#14 ·
Curious to see how this turns up
P180 was one of my favorite cases
#16 ·
Originally Posted by DStanding View Post
Hey what kind of paint did you use for the heat sinks?
Rust-oleum metallic gold. I tried several different brands of gold paint and this one had the best tone. The hearsinks were already anodized black so there was no preparation needed. Anodized aluminum is one of the easiest to paint surfaces.
Everything else that's gold in the case is sprayed with the same. I thought about getting an Asus mobo because it hearsinks are already gold but I'd rather have the fans, hearsinks and fittings all match the exact same color.
It's been a difficult color scheme to get right. To much gold and it becomes gaudy. Not enough and the gold gets lost in a sea of black which is why I decided to paint the case white. It will help the mobo and acrylic tubing using mayhems x-1 oil black pop out at you and the gold becomes an accent color.
What I didn't want was a theme of
BLACK/GOLD
Id rather go
BLACK/WHITE/gold
#17 ·
BLACK/GOLD
Id rather go
BLACK/WHITE/gold
Many thanks. I love how well the gold matches the gold of the caps.
So just clean 'em and spray 'em with a couple coats? No sanding or anything?
#18 ·
The heat sinks were already anodized. Yours probably are too. Anodized aluminum requires no prep work other than being clean. Make sure you get it right the first time because paint adheres to anodized aluminum so well it will be difficult to remove. The Primochill fittings came out of the box as powder coated white. Sorry I forgot to take a pictures before painting them. Powder coat actually has good adhesion with spray paint so I just cleaned them and sprayed. So ya, just light coats with a few minutes in between to allow the paint to get tacky. Be forewarned that these metallic paints come out heavy and thick so less is more.
I wish I paid more attention in photography class I don't know how to light these pictures worth a crap
#19 ·
Omg so happy right now! I found my paracord in the mailbox when I got home from work.
The gold is as close a match as you'll ever get. I was really worried because everybody's idea of what color "gold" should be seems different.
Let it be know throughout the land that rust-oleum metallic gold paint is a perfect match to lutro0 customs gold para cord.
