I've narrowed my choices down to these two 4gb kits,
Crucial Ballistx DDR2-800 "A" revision
Patriot Extreme Performance DDR2-800
The Crucial sticks use the new IC revision, supposedly fixing the high failure rate issue. The Patriot are cheap, and have a decent track record. Does Patriot use the same IC's/PCBs in these as they do in the Vipers? Is the difference just a heatspreader? The other brand I would consider is Mushkin, but I would like to get 8gb, and they're a bit more expensive. I'm partial to Crucial, but I've always wanted to try Patriot. Anyone have any suggestions either way? Thanks.
