I'm looking to upgrade my display and wanted a 27" w/ 1920 X 1200 resolution, but 16:10 monitors are hard to find at a reasonable price. So...
16:9 it is.
Should I go 1920 X 1080 or 2048 X 1152 for resolution?
My priorities are 1. Work (by far) 2. Movies 3. Games, in that order. For work I need as much screen real estate as possible to compare 8-16 documents/images side by side with readable text.
How are HD movies at 2048 X 1152? Does the weird resolution make them blurry?
What about games at 2048 X 1152? Are there any problems, besides the obvious need for a stronger graphics card than I have?
I'm looking at a Dell SP2309W 23". Buying 2 of these would be a better choice than a single 27" @ 1080P, correct?
16:9 it is.
