Headphones broke(left ear), solder to fix it
19K views 26 replies 4 participants last post by  Liero
#1 ·
Hello there.
So, my QPAD QH-90 broke due to pulling in the cable.
FIrst the sound in my left ear started to go away and come back but three days ago the sound in the left ear disappeared altogether.
I decided to try solder it and I managed to get sound in both ears, but there's no bass at all. If I pull out the cable from the computer just a little, I get full sound and bass in my right ear, but no sound or just very low in my left ear.
What could cause this?
I MAY have mixed up the cables while soldering, but I can't find any schematics of the cables but hopefully someone of you know what I can do.
Thanks,
Sincerely
#2 ·
Sounds like your left side + wire is is shorting out with the right side - wire. Post an picture. I can probably point out the correct connections.
#4 ·
Get a multimeter , set in Continuity (a cheap one can cost like 10-15eu i think ) ... and check witch cable correspond to each side. Also you can check if your solder is right, sometimes if you don't clean well the protection the resistance of the cable increase and change the frequency response (more impedance).
Also get a 1.5v battery to check that both driver are in phase, if you apply power to the driver and you see the cone pop out the polarity is correct ...
#5 ·
Funny thing is, I'm part electrician, but the names of everything from English to Swedish is so different I have no clue what you're on about.
Thanks for trying though.
#6 ·
Originally Posted by h1F5solomon View Post
Horrible pictures, but hopefully it works:
http://1drv.ms/1HzBb3g
What I've done now is putting those two cables together since I noticed I got sound when doing it
Just to clarify
#7 ·
This is "Continuity Mode" ... tell me what part you don't understand. Also be EXTRA CAREFUL when you use the solder on the drivers, because some tiny tiny cooper wires come from the coil and goes to the solder pads
off: my english a bit crappy so maybe i did a typo
#8 ·
Shouldn't be much of an issue in this case as it has an separate PCB part. As seen in the picture there there are what seems to be 3 main solder points and 2 smaller point that I would presume are the ones that are for the driver wires.
#9 ·
Originally Posted by Bit_reaper View Post
Just to clarify
To answer both of you:
Your English is fine. It's just I haven't studied electricity in english so I don't know the names for everything.
The part with the battery is the thing I didn't understand as well. Phases and stuff.
#10 ·
To burn the isolation of the wires don't use fire, just apply soldering tin ..., check the resistance of the cable with the multimeter (arround 0.8- 1ohms) and then solder it to the pad.
If you get the headphone working again, check the impedance with the multimeter ( in Ohms mode) u will see a value a bit higher than the actual impedance of the headphones (actually you are measuring resistance ... )
#11 ·
OK in that case I'm fairly sure the wiring should be as follows.
So use the "beeper" and check that it matches with standard stereo jack layout (ground being the same as negative in this instance)
So in actuality on the face of it the connections look good. Could be an cable issue (kabelbrott).
#12 ·
As said on the video: The "common pad" is missing cables because I removed them to try something. You can see both cables unfocused in the middle of the screen.
#13 ·
hmmph..
#14 ·
hmmph..
Yeah that's seems like the correct way to me
But like I said you should measure the connections with the multi meter and actually rather then using the circuit test beep use the ohm setting and measure the resistances.
#15 ·
makes sense?
#17 ·
This is really weird, but if I put the jack like this I have sound/bass in both ears, but if I plug it all in the bass disappears.
What the hell?
Whats probably happening is that its ends up with an mono connection, meaning left channel on the jack makes no contact and the right channel goes to both left and right.
Like so
#18 ·
Yes make sense .... ground to right posive = 56ohms , ground to left positive = 56 ohms and Right and left postive (since the ground is common) 56+56 = +/-112 ohms. Try using the headphones direct without the volume control
Reactions: h1F5solomon
#19 ·
The volume controller is not the problem since it works with my speakers and earbuds.
The cable gets stuck under my armrest and when I move my head the cable pulls, so I guess there may be a "cable issue"? (kabelbrott as you referred to earlier)
I have another headset I'm not using. Should I try take the cable from there and solder it to this one? That way there's no chance of the cable being broken.
Or should I try to fix this and use that as a last solution?
#20 ·
Well.. I got it to work with another headset.
I took the wiring from the other headset and put it into my Qpad one: http://1drv.ms/1LhCHLF
I've noticed there's more sound on the right side though, but I've balanced it out in windows so It should be good now.
Thanks for the help guys.
#21 ·
Good to hear
U have a bad solder in the left side, probabily you don't clean perfectly the insolation and is adding resistance, just check your soldering again ... and use the multimeter
#23 ·
Your need to measure the resistance between the plug contacts and each wire ... not between the driver coils.
#24 ·
Ground between those points were all 0.1ohm
Left between C - G were 56ohm
I'm confused about the "Right" one, since you've done different letters on both pictures.
But from what I could think of It's R to A It 114 ohm, frĂĄn R to D It's also 114 ohm, but frĂĄn R to I it's 0.6ohm.
Like, the left driver only has 2 cables, not three. As you can see on the second picture you posted.
EDIT: Nvm helping me. I ragequitted this **** by ripping this **** apart.
#25 ·
Chill out bro ! jajaja just grab a beer put some relaxing music .... Let see if this image helps
THE POINTS H, I, G, F MEASURE IT FROM THE DRIVER NOT THE PCB !
