So I got a brand new Corsair 300R about 2 months ago and I'm having issues with the front grill.
For those unfamiliar with the 300R and its front panel, it has a mesh grill that covers a built in air filter. Heres a pic. My main issue is that my apartment is quite dusty. I dust often, but I never get rid of it. That, and I have 2 cats. So I find myself cleaning the air filter very often as it gets a light coat quite fast. And since I clean it so often, I'm forced to remove the grill from the front panel that covers the Air filter, this is where I'm having my issues.
This is how the Front grill is connected to the front panel:
(Not my pic, just pulled from google, it was faster)
So its held on by small pieces of the mesh itself being inserted into slots and being bent in place. I have no idea who's idea this was a Corsair, but that case designer should get a serious reprimand for even suggesting this low quality approach IMO. The reason I'm so annoyed? I bought this case only 2 months ago and I'm about to lose the ability to even reattach this grill because the metal from the mesh you bend around the panel is about to snap. Who would have thought that bending a piece of metal back and forth over and over would cause it to crack?
So I'm looking for alternative ways to reattach this without having to do something like zip tie it and cut it every time I have to clean it. Has anyone else had this issue and what did you do to remedy the situation? I find the idea of having to ghetto rig something I bought brand new ~2 months ago back together to almost be insulting as a consumer. Corsair, I am not impressed.
I have only bought a handful of Corsair products in the past and my last CLC (H50) lasted a heck of a lot longer than I ever imagined and performed pretty solid all things considered. But the quality of this case (budget segment or not) leaves a lot to be desired, and leaves me feeling buyers remorse.
Any suggestions on what I can do to keep this grill on without ghetto rigging it there? Or is that really my only option? Or would I be better off cutting the filter out and finding a way to make that removable? Thoughts/Suggestion?
