Need water cooling loop input
1 reading
2.2K views 4 replies 4 participants last post by  kosmok1000
#1 ·
450
I would like your comments please.
Should I make two separated loops since I have two pumps on the Koolance 450X2 reservoir, or one loop and go from the CPU to GPU'S?
the way I have now it is reservoir/pumps to two 480 rads to CPU from to another 480 rad to GPU'S and back to reservoir, but this way only uses on pump.
I their a way to use both pumps on one big loop? or is better to have two loops?
thank you for your input.
Sorry but english is not my main languish.
#2 ·
I have tried dual loops and there is really no need. Do one big loop!
#4 ·
BIG LOOP! MY question... Why is the bottom rads fittings on other end of case the top rad? If you turned it, the lines wouldnt have to be so long, and would help shorten things dramatically. Nothing wrong with two pumps in series, it wont increase flow rate, but will be redundant in case one pump fails.
