Have not bought intel since c2q... need some helps
i will be running quadfire
i want the best mobo for it and ocing
what do you recommend?
everything will be under water and i would like the board to have a full block
last question
is the quadfire 16 16 16 16 worth it from this board?
http://www.newegg.com/Product/Product.aspx?Item=N82E16813157327
thanks ~
needs to be
2011
8dimms
quadfire
waterblock for mobo thanks !~
got a 3930k ( heard they are better then the 4930k? )
last question
thanks ~
needs to be
2011
8dimms
quadfire
