Only the Gigabye that have completely naked VRM is hotter Asus, reaching 95°.Roundup: Six Mini-ITX Mainboards on Intel Z77 Chipset.
"We measured the temperature of the VRM components during our stability tests to see how efficiency they are and how they can sustain CPU overclocking. It is undesirable for mini-ITX systems to have too hot components."
Frequency (HT ON/OFF) [SIZE=5]|[/SIZE] Full Load VCore [SIZE=5]|[/SIZE] Max cores temps (Tamb) [SIZE=5]|[/SIZE] Delidded or not [SIZE=5]|[/SIZE] Cooler [SIZE=5]|[/SIZE] Username
Frequency [SIZE=5]|[/SIZE] Full Load VCore [SIZE=5]|[/SIZE] Max cores temps (Tamb) [SIZE=5]|[/SIZE] Delidded or not [SIZE=5]|[/SIZE] Cooler [SIZE=5]|[/SIZE] Username
Frequency (HT ON/OFF) [SIZE=5]|[/SIZE] Full Load VCore [SIZE=5]|[/SIZE] Max cores temps (Tamb) [SIZE=5]|[/SIZE] Cooler [SIZE=5]|[/SIZE] Username
Frequency [SIZE=5]|[/SIZE] Full Load VCore [SIZE=5]|[/SIZE] Max cores temps (Tamb) [SIZE=5]|[/SIZE] Cooler [SIZE=5]|[/SIZE] Username
Frequency [SIZE=5]|[/SIZE] VCore [SIZE=5]|[/SIZE] Delidded or not [SIZE=5]|[/SIZE] RAM [SIZE=5]|[/SIZE] Cooler [SIZE=5]|[/SIZE] Username
Frequency [SIZE=5]|[/SIZE] VCore [SIZE=5]|[/SIZE] RAM [SIZE=5]|[/SIZE] Cooler [SIZE=5]|[/SIZE] Username
:clock:[URL=http://www.overclock.net/t/1404781/official-asus-p8z77-i-deluxe-owners-thread-club][B] Official Asus P8Z77-I Deluxe Owners Thread and Club[/B][/URL]:clock:
added also signature codeHow to join the club
Post a simple photo of your P8Z77-I DELUXE (also only the box is good), with your nick + OCN initial.
Like this: http://i.imgur.com/k83oR6Ol.jpg
If you have a build log thread, or a post with other nice info and photos about your rig, indicate it. The link will be added next your nick in the owners list.
I think it is more comfortable to hold a post for each chapter (see the index), rather than using a single post with many buttons spoiler
Here is my build log http://www.overclock.net/t/1347447/build-log-lori-lemaris-watercooled-ft03-miniOriginally Posted by par
Added!Originally Posted by WiSK
My photo does include my OCN nick but it's hard to spot: on the ATX pin remover in the middle.
All the BIOS next 0607 (then 0704, 0706, 0801, and 0902) have little bug about bluetooth controller.
The controller can not be disabled also if it is switched off from BIOS, it's always detected by Windows.
Asus is aware of the problem, and still has not been resolved.
upppOriginally Posted by par
what is broadcast mode?
to better understand:
in bios bluetooth controller is disabled, but in windows it result enabled: http://i.imgur.com/X02A1.png
you understand? if you have bios next 0607 you can do a fast try?
With broadcast mode I mean the setting that says 'allow other Bluetooth devices to find this computer'. And there is also an option called 'turn adapter off'. So yes you will have the driver, and the device in the device manager list, but it will be inactive.Originally Posted by par
NICE SUGGESTION! thnx!
Doesn't the MCP35X have two connectors? Power connector goes to a molex and takes the full 12V to power the pump. The 4-pin fan connector just does the PWM, doesn't take any power.Originally Posted by ratzofftoya
So, looking over the manual, it looks like there are two places to plug in PWM cables, the CPU_FAN header and the CHA_FAN header. The manual cautions that the CPU_FAN one only supports up to 1 AMP of current, so I don't think I can plug my Swiftech MCP35X PWM in there. It doesn't say the same thing about CHA_FAN...You guys know if that can handle more than a 1 amp?
Ohhh, I see. So the power over the mobo PWM headers doesn't matter if you're powering the pump through molex; the PWM will work fine?
I have a Apogee Drive 2 which uses the same system. I've tried the PWM connector on motherboard fan header, on an Aquaero fan controller, and even using an adapter I connected the pump to my graphics card (see pic, it's the blue sleeved wire ending in white connector). All works because it only uses the PWM signal.
