8,701 - 8,720 of 9,078 Posts
No, on amd site, 2 days ago, it was still 6.07.
Mate, as of today on the ASUS website there are the AMD Chipset Driver v6.10.02.1849
These ones, released yesterday on the AMD website, are AMD Chipset Driver v6.10.17.152
So, the ones from the AMD website are newer than the ones from the ASUS website, like dansi said, and your statement "On Asus site since some days now" looks to be incorrect. Am I missing anything ?
Ok, if you want….
I think it works, mostly for really low load tasks with bursty turbo.
My pc used to reset itself with the current -CO, in either full screen HEIC iphone photos or playing full screen video in Edge sandbox mode.
Since using CS, no more resets at the same -CO
Never faced PC restarts from my curve values, just OCCT AVX2 fails (usually 2 thread fails a bit quicker). But I'll play with it and see if I can notice anything.
...or you could unpack both driver packages and verify drivers themselves. Chances are the drivers are identical.
I checked that, to be sure that wasn't the case. The AMD PSP Driver went from v5.33 to v5.34 , and the AMD PPM Provisioning File Driver went from v8.0.0.43 to v8.0.0.45, compared to the ASUS website versions. I don't understand what he was referring to, I just want to use the latest drivers tbh.
Hi There,
I have some weird stuff going on with my PC and I am not able to figure it out what is happening...
Main Issue :
Whenever I plug in the external USB 3 case SSD (4tb samsung 860 100% health) The MX Master Vertical Mouse starts lagging but almost unusable. As soon as I disconnect the usb or I plug into the usb c it works fine afterwards..
It seems that the Gigabyte usb 3.0 controller has issues... I found the workaround by using the usb c :D or the 3.2 USB plugs.
Second Issue - Might be related to the CO -30 (decreased it to 25 - still testing)
From time to time, after not using the computer for about 30 minutes or so, the Mouse the keyboard(wired) lags and windows itself as well..
latest BIOS Patch will be applied soon. But it is kinda weird, dunno if it is AMD or MOBO or Windows related..
Any Idea?
Hi There,
Main Issue :
Any Idea?
USB 3 link produces strong 2.4ghz interference
CS allows me to get more aggressive -CO on all core load.
The new Aida64 finally fixed the SHA3 problems with X3D? PC does not reboot on a first try at current -CO ....tears/ss 😭
The latest AIDA64 update introduces an enhanced SHA3 benchmark
New features & improvements
  • AVX-512 accelerated benchmarks for AMD Ryzen 9000 Granite Ridge CPU
  • Enhanced support for AMD X870 and X870E chipset motherboards
  • Improved support for hybrid processors
  • Further optimized SHA3 benchmark on AVX-512 capable processors
Can someone give me a Direct-Link for the v6.10.17.152.
On the AMD Page, I only see the older one.
Refresh the web page with Ctrl+F5 maybe ?
I still get the old one. If I'm using a VPN with Location in the Netherlands or England, then I get the new one. :rolleyes:
Reactions: Kelutrel
Clearing cache might work too. Firefox sometimes caches pages because of how frequently I check for driver updates. I should probably fix this obsession :p
Now the new Version is Available on my normal German IP.
Mine still reboots using my game-stable CO values.
