9,061 - 9,078 of 9,078 Posts
Can anyone run the "Latency / Bandwidth benchmark" on OCCT?
I'm questioning my speeds, can only find 1 screenshot which mentioned about 400-500+GiB/s in L3 Cache read on a 7800x3d as well.
Meanwhile mine can't even break 200 GiB/s so i'm questioning if something is wrong.
AIDA64 does provide me about +- 680 on the benchmark but latency is quite high there.
can someone give me the TLDR for an easy and stable overclock?
PBO. Tjmax = 85°C and Curve Optimizer – 20mV?
also one question:
ProfileAvg ClockEff. ClockMax TempAvg TempScore
Cinebench Defaults4682 MHz4624 MHz82.9 °C80.3 °C1053
Cinebench –20 CO +200 MHz4815 MHz4705 MHz82.8 °C80.3 °C1097
Cinebench –20 CO4825 MHz4805 MHz82.8 °C81.3 °C1098
Why is the score and effective clock with a –20 all-core Curve Optimizer the same as –20 all-core Curve Optimizer plus a +200 MHz max CPU boost-clock override? Should the latter score higher?
also one question:
There isn't really a TL;DR because every CPU is different and you have to find the limits for the one you received.
The "easiest and most stable" overclock is just enabling PBO and letting the CPU find it's own limits with the default voltage/frequency curves. The next step is finding how low you can set the all-core CO while remaining stable in something like CoreCycler with one its Ryzen configs that use y-cruncher. The step after that is finding per-core values, which CoreCycler can kind of do automatically for 7000 series - you have to set them pretty low to start, then let it work its way up until its stable. If you're looking for easy, I wouldn't go much further than that.
As for your score with +200 vs without, that +200 just moves the boost frequency limit, which you aren't hitting, so it is irrelevant.
youre the GOAT thank you!
Can confirm, CoreCycler with y-cruncher is pretty good for that:
  • Haha
Reactions: fbsrkc06
Jesus... -18 as your lowest CO on a perf 1 core on CCD1... My 7950X3D can only do -1 on one of them, which means it's basically running stock, and that's after RMAing the first one I got because it couldn't even pass AIDA SHA3 stock.
My 7950X3D was like your (and I had two RMAed before that, 1st one died, 2nd wasn't passing occt stock), I had two cores I couldn't even do -1 or barely. That 9950X3D is definitively better in that way.
  • Haha
Reactions: fbsrkc06
Dumping My Bios Settings on
CPU : Ryzen 7950X3D
GPU : RX 6800XT
RAM : M-DIE (V1) G.Skill 6000mhz 30CL
MB : ASUS ProArt X670E-CREATOR
Here for reference in case anyone looking for it.
These settings aiming toward all aspect of the machine, Performance, Power Consumption, Heat and also Security.
If you are after Maximum Performance and Lowest possible Latency this is NOT for you, Some setting might have performance as cost. The same with anyone what want to run their system at maximum efficient and lowest power draw, this setting is no where close to Eco mode and enhance all power saving features
Yes, This latency can achieve with SVM Enable.
Dickey Lee like this result (old song reference)
Hello, new x3d owner her :
Has anyone else seen this issue with a new build?
System:
  • Ryzen 7 7800X3D
  • Asus TUF Gaming B650-E WiFi
  • Radeon 7900XT
  • Corsair Vengeance 6000 MHz RAM
The problem:
When I leave the system idle on the desktop for a longer time, Adrenalin eventually shows very low clocks (around 0.5–0.8 GHz), and at some point the CPU just sticks to a single low clock speed.
HWInfo and Windows then show that only 3 cores are actually active, with the clocks stuck at around 3.8–4.2 GHz according to Task Manager. In Cinebench R23 I can’t reach full CPU utilization anymore (max ~86%), the score drops significantly, and not all cores ramp up.
A reboot fixes the issue immediately.
When everything works normally, I see a stable 5 GHz boost in Cinebench, and even after an hour of load temps stay below 75°C.
It almost feels like the CPU goes into some kind of deep sleep state after being idle too long and then never fully wakes up.
Power plan is set to Balanced.
Has anyone experienced this before or knows what could cause it?
System:
  • Ryzen 7 7800X3D
  • Radeon 7900XT
The problem:
Use Hwinfo and observe the C state.
if it's C-state change the APCI setting I show above.
