Q6600 Bottleneck A GTX 580?
18K views 119 replies 31 participants last post by  silentnight
#1 ·
Title says it all, will my Q6600 @ 3.4 Ghz bottleneck my GTX 580? I play games at a 1920x1200 resolution. My guess is no at those resolutions but I'm new to a lot of this
#4 ·
Me thinks you'll be fine.
#7 ·
Fast replies, thanks all, but not even with games that only support dual-core?
#8 ·
At 3.4? Yes it will, more on certain games than others. And the games that "only" support dual-core are the majority of them, since only a few support over 2. So a faster dual would outrun your Q6600; if you don't play BFBC2 or GTA4 for example, a 4.0 E8400 on that 750i would truthfully be a better gaming setup than your Q6600. But you'd be taking a step backwards for general performance in encoding.
What matters most is how well your setup does with the games that you play. If you have no issues with framerates, than who cares?
#14 ·
I disagree.
#20 ·
Well in my current sig rig iv'e swapped this E8600 out for a 3.6 Q9400 and my FPS stay the same..
No bottle neck really.
Originally Posted by Track;12568454
It will only fake-bottleneck your rig.
Which means, no, you can't get 150FPS in Crysis.
And no, you're not going to get 20,000 points in 3DMark06.
But you WILL get 60FPS in ANY game, which means that if you bought a better CPU, you'd hardly notice the difference.
#25 ·
Pretty believable that a 4.5GHz E8600 does well against a Q9550, but I wouldn't go so far as saying it "eats it." I had a 8400 at 4.2GHz myself, and feel that a Q6600 was a nice upgrade even clocked lower. I don't think a Q6600 would bottleneck a 580 as my Q6600 whistles while my 4870X2 runs at full load.
