Now that Skylake is out, it uses DDR4, and we know how much both Z170 and X99 builds cost.
With that said, why would someone opt for Skylake over Haswell-E?
6700k is about $25-50 cheaper over the 5820k. Neither one comes with a CPU cooler.
Z170 boards are not much cheaper over X99 boards. Both platforms are in it for the same DDR4 cost.
Obviously you can easily skew this to make the Z170 platform the obvious bang for buck choice, but you can also make the X99 look like the better buy just as easily.
I usually invest in the new mainstream intel platform around its release. But this time, I think I'd rather spend the extra measly $100 at this point and just go 5820k.
Ok fine, some of you will say that you don't need more cores. You have to admit, right now, the Haswell-E is looking to be a better value over Z170, right?
Sure, you could also go with the i5 6600k, and honestly, that to me is Skylakes saving grace. Their 6700k cost of admission is too close to the 5820k.
What are your thoughts?
