So I tried to install the EK Coolstream XE 480mm radiator with the top drop-in mount for the Caselabs Merlin SM8 case, but it seems that it wont fit correctly due to clearance issues with the radiator being mounted on the bottom of the drop-in mount and the case chassis being in the way.
The only way I can get the radiator to fit is to create a gap using longer screws and washers. This will probably create a gap of maybe 8-9 mm for the pull fans. The push fans are attached directly to the underside of the rad. Will this gap between my pull fans create any sort of noticeable temp difference?
