[techPowerUp] Lian Li Armorsuit PC-P80R Spider Edition
6.9K views 34 replies 28 participants last post by  NCspecV81
#1 ·
Back in January, Lian Li showed this case at CES. Although it was originally designed for show purposes only, Lian Li received such a favorable response to the design that they decided to produce it for the masses.
Features:
* Hand Crafted, Made in Taiwan
* Hair Line Brushed Anodized Aluminum Finishing
* Freedom of Hardware Setup
* Huge Internal Space for Extended ATX Motherboard
* Graphics Card Holder
* Support up to 220mm Long Power Supply Unit
* Three Red LED Intake Fans in The Front
* Support Liquid Cooling System
* Rear 12cm Red LED Exhaust Fan
* Linear Fan Speed Controller
* Built-in Easy Clean Air Filter
* Top Mount 14cm Red LED Fan
* Removable Top Cover
* Easy Detachable Front Panel Door
* Removable Motherboard Tray Design
* Sound Insulation Rubber Strip in the Door
* Anti-Vibration Kit on Chassis
* HDD Mounting kit with Tool-less Anti-Vibration Design
* Multi-Media I/O Ports with Dust Free cover
* High Quality Aluminum Case Stand with Anti-Vibration Rubber Pad
* Multi-Door Swing Direction Design
* Top Cover with Sound Dampening Cover
* Security Lock on Door Panel
* Theme Side Panel
Source
#6 ·
for their photoshoot, they put a cheesy photoshop-lens-flare-of-death in the background XD
sorry, couldn't help myself. The artist in me sees faults.
But it does look cool
#10 ·
posted here repeatedly. Not that it matters but a case should not be one of the most expensive parts of your system. Especially when there are so many $200 range cases that give equal or better airflow to choose from.
Antec 1200 (when available)
Coolermaster cosmos S
coolermaster stacker 830 series
thermaltake armor
antec 900 (smaller mind you)
etc., the list goes on...
Reactions: Sazar
#13 ·
Here is a better "red" case for half the price...
#14 ·
thermaltake armor
Why not?
The case, along with the PSU, is one of the few items that actually last. The CPU, GPU, motherboard, these are all useless once the next generation reaches mainstream prices. The case will last through all of them.
With a Lian Li it may even last past the ATX generation, even if the next mobos are substantially different you can just get a new mobo tray for it.
Personally I didn't skimp on the case precisely because it'll last longer than just about any other component.
#15 ·
My point is that the difference in quality between a $200 and $400 case is what? Custom paint?
Any case under a $100 is suspect in its quality. Sure there are exceptions like the antec 900 and coolmaster cm690 but once you get into the $200 range, you get top quality.
I bought a silverstone TJ-09 Temjin last week and returned it two days later for the cosmos S I currently have.
The TJ-09 was a $300 case with a very poor airflow design. My prior case, a stacker 830 easily bested the TJ-09 in every temperature sensor, video cards mb, cpu etc.
And it was only $200 and all aluminum.
Just like we won't see to many of the thermaltake swords around here (although I almost bought a thermaltake tai-chi awhile back before I regained sanity).
Also, cases need to be changed occasionally. I bought a new case recently, not because my stacker 830 was not amazing (which it was) but because I was tired of looking at it for over a year.
#16 ·
thermaltake armor
The case is made of 100% pure aluminum inside out. Someone has to fill the high-end case market.
#19 ·
HORRIBLE.........UGH my eyes hurt.
#21 ·
thermaltake armor
You forgot that RocketFish one
Made by Lian-Li, sold at BB for ~$70, what's not to love?
I've never really liked most Lian-Li cases...but the RocketFish one and now this...they've changed my mind.
~Gooda~
#24 ·
$400 for a case, LOL! I'd take a Phenom over that any day.
#26 ·
"MSRP to be well over $400 US Dollars".......That doesn't mean it will be $400.
