This is something which have bugged me for a while and have annoyed me countless times so now i am going to make a thread about it and talk about the problem at hand.
That problem is all online PSU calculators are crap and totally useless and give you bogus information if not outright misinformation.
To get to the point all of them give you the end user numbers that are much higher then what you are ever going to see in real life.
Now there are many theories as to why one of them is they are all paid off by the PSU brand/manufacturers to give numbers too high so they can make more money by selling you higher wattage PSU´s.
Another one is they are doing it do cover their own butts in case you have an el cheapo crappy PSU that cant do its rated wattage.
Now my own thinking is they have moved over to peak wattage numbers instead of continuous wattage but they are not telling anyone about this nor is it stated anywhere.
To explain what peak wattage is we need to talk about a peak rated PSU and to explain in plain english its a PSU that can do UP to its rated wattage for a short time but cant do it 24/7.
Quote
What is the difference between "continuous" and "peak" ratings?
Some power supply units are rated for continuous output while others are rated at peak. "Continuous" means that the power supply is rated to run at it's maximum capability for no pre-determined period of time, while "Peak" indicates that the power supply will only run at the specified wattage for a brief period of time, possibly only a few seconds or up to a minute. This number is typically about 100W more than the power supply's actual continuous rating.
Check out my Why the AMD and Nvidia power requirements are wrong for more info about peak wattage and how it has impacted AMD and Nvidia power requirements and why there is also so much misinformation there
To get back on track my theory is all of these so called calculators and sites are now using peak wattage means they give you numbers that are 28% too high which actually make sense if you look at it that way.
So long story short if you are going to use one of the so called bogus broken crappy useless calculators know that the numbers most likely are in peak numbers and NOT continuous wattage.
So again dont trust the info you get from all of these sites its wrong!
If anyone has any info that could shred some light on all of this it would be welcome.
Quote
