Hello! I have a question for you guys, I Just purchased a new AMD FX-8370 CPU and an ASUS Radeon R9 390 for my PC witch are still coming in the mail. Will both the new CPU and Video Card work with the Crosshair IV Formula? I know I should have done more research before buying them, but I got excited and figured they'd work. I've read that the FX-8350 will unofficially work with the 3029 BIOS. http://rog.asus.com/forum/showthread.php?30386-CHIV-AM3-Support-Can-I-install-an-FX-8350-in-my-Crosshair-IV-Formula
My current rig with its Phenom II 1090T 3.7ghz and crossfired Radeon HD 5970s, all water cooled with 8gigs of ram, Can 'run' Fallout 4. BUT, the game has to be on minimum settings with shadows turned off and FPS unlocked in the .ini file, and ccc settings are all on performance. And the game is still extremely laggy and choppy. And at some points it freezes and requires a restart. This is with crossfire turned on/off and video cards OCed and not. So I figured it was time for an upgrade.
Question: Will the FX-8370 AND the R9 390 work in the CrossHair IV Formula, or do I need to get the Formula V (rather not)?
BIOS: 3029
Windows 7 64
8gigs Memory DDR3
Thank you!
-Peter
BIOS: 3029
Windows 7 64
8gigs Memory DDR3
Thank you!
-Peter
