Dr. Kerns H. Powers, a member of the SMPTE Working Group on High-Definition Electronic Production, first proposed the 16:9 (1.77:1) aspect ratio in 1984,[1] when nobody was creating 16:9 videos. The popular choices in 1980 were: 1.33:1 (based on television standard's ratio at the time), 1.66:1 (the European "flat" ratio), 1.85:1 (the American "flat" ratio), 2.20:1 (the ratio of 70 mm films and Panavision) and 2.35:1 (the CinemaScope ratio for anamorphic widescreen films).
Powers cut out rectangles with equal areas, shaped to match each of the popular aspect ratios. When overlapped with their center points aligned, he found that all of those aspect ratio rectangles fit within an outer rectangle with an aspect ratio of 1.77:1 and all of them also covered a smaller common inner rectangle with the same aspect ratio 1.77:1.[2] The value found by Powers is exactly the geometric mean of the extreme aspect ratios, 4:3 (1.33:1) and 2.35:1 (or 64:27, see also 21:9 aspect ratio for more information), √47/15≈ 1.770 which is coincidentally close to 16:9 (1.77:1). Applying the same geometric mean technique to 16:9 and 4:3 yields the 14:9 aspect ratio, which is likewise used as a compromise between these ratios.[3]
While 16:9 (1.77:1) was initially selected as a compromise format, the subsequent popularity of HDTV broadcast has solidified 16:9 as perhaps the most important video aspect ratio in use.[citation needed] Most 4:3 (1.33:1) and 2.39:1 video is now recorded using a "shoot and protect" technique[4] that keeps the main action within a 16:9 (1.77:1) inner rectangle to facilitate HD broadcast[citation needed]. Conversely it is quite common to use a technique known as center-cutting, to approach the challenge of presenting material shot (typically 16:9) to both an HD and legacy 4:3 audience simultaneously without having to compromise image size for either audience. Content creators frame critical content or graphics to fit within the 1.33 raster space.[citation needed] This has similarities to a filming technique called Open matte.
After the original 16:9 Action Plan of the early 1990s, the European Union has instituted the 16:9 Action Plan,[5] just to accelerate the development of the advanced television services in 16:9 aspect ratio, both in PAL and also in HDTV. The Community fund for the 16:9 Action Plan amounted to €228 million.
In 2008, the computer industry started switching to 16:9 from 4:3 and 16:10 as the standard aspect ratio for monitors and laptops. A 2008 report by DisplaySearch cited a number of reasons for this shift, including the ability for PC and monitor manufacturers to expand their product ranges by offering products with wider screens and higher resolutions, helping consumers to more easily adopt such products and "stimulating the growth of the notebook PC and LCD monitor market".[6]
In 2011, Bennie Budler, product manager of IT products at Samsung South Africa, confirmed that monitors capable of 1920×1200 resolutions aren't being manufactured anymore. "It is all about reducing manufacturing costs. The new 16:9 aspect ratio panels are more cost-effective to manufacture locally than the previous 16:10 panels".[7] Since computer displays are advertised by their diagonal measure, for monitors with the same display area, a wide screen monitor will have a larger diagonal measure, thus sounding more impressive. Within limits, the amount of information that can be displayed, and the cost of the monitor depend more on area than on diagonal measure.
In March 2011, the 16:9 resolution 1920×1080 became the most common used resolution among Steam's users. The earlier most common resolution was 1680×1050 (16:10)
