3dmark score lower than others with same hardware..any ideas?
1 reading
10K views 8 replies 4 participants last post by  ThrashZone
#1 ·
I seem to have gotten a bit lower 3dMark score vs other people with the same hardware. Any ideas why? I turned off MSE per another users recommendation yesterday, but I didn't adjust any other settings other than tell it to sync all my cores.
https://www.3dmark.com/spy/3555700
Wondering if it could be related to the 650w EVGA Gold PS that people recommended isn't enough? I am not sure how I can tell.
Here is my build.
PCPartPicker part list: https://pcpartpicker.com/list/QYDXP3
Price breakdown by merchant: https://pcpartpicker.com/list/QYDXP3/by_merchant/
CPU: Intel - Core i7-8700K 3.7GHz 6-Core Processor ($329.00 @ Amazon)
CPU Cooler: NZXT - Kraken X62 Rev 2 98.2 CFM Liquid CPU Cooler ($147.32 @ OutletPC)
Motherboard: Asus - ROG MAXIMUS X CODE ATX LGA1151 Motherboard ($299.28 @ Amazon)
Memory: G.Skill - Trident Z RGB 16GB (2 x 8GB) DDR4-3200 Memory ($216.99 @ Newegg)
Storage: Samsung - 960 EVO 250GB M.2-2280 Solid State Drive ($117.89 @ OutletPC)
Storage: Samsung - 860 Evo 1TB 2.5" Solid State Drive ($284.99 @ Newegg)
Video Card: Asus - GeForce GTX 1080 Ti 11GB STRIX GAMING OC Video Card
Case: NZXT - S340 Elite (White) ATX Mid Tower Case ($79.99 @ SuperBiiz)
Power Supply: EVGA - SuperNOVA G3 650W 80+ Gold Certified Fully-Modular ATX Power Supply ($79.89 @ OutletPC)
Case Fan: NZXT - Aer RGB120 61.4 CFM 120mm Fan ($28.99 @ SuperBiiz)
Monitor: Dell - U3415W 34.0" 3440x1440 60Hz Monitor ($613.00 @ B&H)
Keyboard: Corsair - K70 RGB Wired Gaming Keyboard
Mouse: Logitech - G900 CHAOS SPECTRUM Wireless Optical Mouse ($103.91 @ Amazon)
Other: NZXT AC-HPL03-10 HUE+ Extension Kit ($20.99 @ Amazon)
Other: EVGA 100-CW-1300-B9 Power Supply Cable Set ($78.39 @ Amazon)
Other: NZXT Internal USB Hub ($21.47 @ Amazon)
Other: NZXT HUE+ & Aer RGB140 Fans Bundle Pack RGB 2x 140mm Aer Fans Included ($77.26 @ Newegg Marketplace)
Total: $2499.36
Prices include shipping, taxes, and discounts when available
Generated by PCPartPicker 2018-04-03 21:22 EDT-0400
#2 ·
PSU should be fine...haven't looked into the guts but if it's a lesser build it shouldn't affect your score.
Overclocks bro, are you throttling anywhere? Mainly the GPU.
OC the CPU, RAM and GPU and you should have scores like everyone else. Make sure you don't have a bunch of NZXT and motherboard bloat killing your score.
Edit: Turning off MCE will actually hurt your score if you aren't overclocking anything.
#3 · (Edited)
Need much more details such as :
overclocks & voltages (are you delidded?)
Windows power plan
temperatures
memory settings
motherboard short duration current limit
GPU power limit
edit: are you running 2133MHz RAM? It's mainly your CPU score that's behind , your graphics score is okay
#5 ·
Then your overall score is being held back by 4.3GHz all core turbo on CPU.
Also your Timespy result states you are 2133MHz RAM so you might want to look into that.
#6 ·
Hi,
Yeah I doubt anyone else is on default cpu clocks and memory that low either
Juice it :)
#9 · (Edited)
So I adjusted the XMP and put the memory to 3200. And it still got a low score, less than the last time! WTH!
https://www.3dmark.com/3dm/25955167
Any other ideas? Or recommended settings for me to juice it.
Hi,
You only juiced the memory
Your processor is only at 4.4 I believe that is lower than default turbo of 4.7
You should read through this
http://www.overclock.net/forum/5-intel-cpus/1621347-kaby-lake-overclocking-guide-statistics.html
http://www.overclock.net/forum/5-intel-cpus/1632870-skylake-x-kaby-lake-x-combined-discussion.html
#8 ·
The memory was never going to make or break your score. 5ghz with 2400mhz is going to score much better than 4.8ghz with 4000 mhz.
There's a plethora of guides and info on this site alone. You can read one and get a stable OC in a single day...it may take longer without the experience but it shouldn't take too long to find a good clock speed.
