Hi.
I decided to update my system after two years for something more powerful for gaming. I game in 4k and I know normally I'll be gpu restricted. But still I have seen bechmarks 5900x beating the 10900k with good rams and a beefy gpu. I got the Asus 3090 Strix and I even had a lower 8700k @5GHZ (lower than 10900k).
The sintetic benchmarks are superb comparing to the 8700k @5GHZ. The problems comes with gaming, my main usage.
Gaming and graphics benchmarks are slower with the 5900x than 8700k @5GHZ with the same settings with the RTX 3090.
My build is:
Asus Crosshair viii dark hero (570x).
5900x with Arctic Freezer ii 420.
G.skill trident z 2x8gb @3800mhz 15.15.15.35. Infinity fabrik 1900. 1:1.
Asus Strix 3090 OC.
Samsung 970 pro 1tb.
Ax1200w corsair psu Platinum..
I have tried diferent methods with no success.
1) All cores @4.7ghz.
2) PBO OC. It's get to 5.150 at some points adding 100mhz in bios. Rest of cores around 4.475mhz when benchs.
3) Dinamic OC. It's a mix of both PBO and all cores.
Drivers, bios, windows are up to date.
I have been tweaking the bios up and down for days, reading reviews and forums with no luck. I only use BIOS go oc. Never tried Ryzen Master but I don't think it won't change much.
Any suggestions or ideas to improve performance in games-graphic benches? 5-7pfs less in games is a lot for a supposed to update of the system.
My build is:
Asus Strix 3090 OC.
