Sleep is good !
As to your previous post, I also wish HWInfo would move the WHEA errors further up in the table, though that is probably a custom option anyway in HWInfo. When I'm taking screenies of the 5950X system, it is on a 48 inch LG/4K, but when I do OCN & visual prep, it is on a 27 inch Samsung / 1080p (for another week, then it is moving-files time ) so my other gripe with HWInfo is that it can have pages upon pages of data that are hard to display or share all at once, depending on the usual settings chosen, and important stuff on the bottom rows can be missed.
WHEA errors are important, not least as they show the whole system response, including even various non-RAM specific errors which nevertheless may have been indirectly triggered by a RAM issue. Somewhat related, very tight tFAW and also tRAS can pass various RAM-specific tests but can sometimes lead to a bit of stuttering in certain games ('low 1% and 10% frame times'), even if overall / average frame rate is great.
Your earlier system pic showed some decent cooling arrangement and DIMM temps, far better than what I've seen elsewhere. Still, why not try to see if 1.55v 'works' at the same speeds. I think you were at about 40 C DIMM temp and that's 'just slightly yellow, not deep red' but lowering RAM voltage just a bit is worth trying.
Also, I'm not sure if you have ever seen / used
> this tool (there's also a whole thread on it at OCN). While it ostensibly is only for AMD Ryzen RAM tuning, it will get you very far down the road on B-die, including secondaries etc (just choose the fastest Ryzen option as a stand-in for your Intel, then select your Samsung B-die and check 'safe', 'fast' etc). I've used it on both Intel and AMD (same Samsung B-die GTZR family in use) and the author is a very well known specialist. It makes diving down the rabbit hole a lot easier.
When I build a Threadripper system about two years ago, I only had 8 sticks of GSkill GTZR on hand which were actually marketed for Intel Z270/370 etc and not even on the TR mobo's QVL list. I got it fairly tight, but then found the Ryzen Dram calculator...it helped to confirm those secondary timing parameters I had been guessing at. It may not go all the way up to the speeds you want, but just chose the highest one as a good foundation from which you can experiment further.
Finally, if you want to see how deep the rabbit hole goes, check out HWBot / Memory and benches such as
> this one . DDR4 4400 CL12
or DDR5 7600 CL 30
, both on LN2 coz cool RAM is happy RAM...the DDR4 (for now) still trumps the DDR5 because of the tighter latencies, given the always present trade-off between bandwidth and latency, but soon, DDR5 will take it, IMO.
