21 - 40 of 376 Posts
Discussion starter · #22 ·
Hi. I'm running my memory with 3600@CL14 using following timings:
My RAM Frequency is 1.45,
SOC is 1.1
Both DDG* are 1.05.
I passed Extreme1 Anta777 preset in TestMem5 (the 2 hours one) with no error. However I want to run my memory 24/7.
I don't turn off PC when I leave house or go to bed so I want to make sure that my parameters and values are optimal for safe use?
I don't know much about memory overclock. If someone could tell me if there is anything I can change / lower to make it safer and stabler in long term I would really appreciate.
Also can anyone suggest some super heavy preset for TestMem5 that I can leave overnight for 8-10 hours to make sure I don't have any problems? Anta777 2 hours doesn't seems to "enough" in my opinion. Yesterday my game crashed without any error (no error in event viewer either) so I'm not sure if its just a game or memory related.
You can edit the number of passes in the .cfg file :)
Reactions: MarcHays
Discussion starter · #24 ·
Thank you for your reply. What is the best config for stress test the memory for prolonged time? I want to 10000% sure that my memory is stable and won't cause any issues.
Extreme1 is probably the most popular but Ollie is also recommended by some
Be sure to click "load config and exit" after making the alteration to the config file :)
Is there somewhere an overview what the various errors in certain tests mean for the Extreme1@anta777 config? E.g. when to modify the VDIMM, the VSOC, the tRFC, the latency, etc?
Without such an overview it's pretty hard to figure out what setting to actually change.
2469765
Someone shared it on another thread here on overclock.net.
I've seen it posted a few times.
If it's always an image, no wonder that it's hard to find. I did find a couple of this info spread out here any there, but not a list that concise. What I actually do wonder though, is this for the ante777 config or for the default one? Because the info bits I did find did not specifically mention the ante777 config, and for some posts it was even visible that the default config had been used. :unsure:
I'm sure it's for the usmus test.
Reactions: sp00n82
Keep getting "Memory Manager #X not started. Fatal error, programm stopped!" any fix?
Hello! I downloaded testmem5 with the config files from the first page. I think I have figured out how to run everything, renaming cfg to MT.cfg to get it to run. Unfortunately the test that runs is always 3 minutes 30 sec. Every time. Is there something I'm doing wrong? I've seen others mention running the test for couple hours.
This was my log:
========= TestMem5 Log File =========
Customize: Default @serj
Start testing at 15:06, 816Mb x16
Testing completed in 3m 29s, no errors.
Hit 'Load config and exit' browse to your TestMem/bin folder, load Extreme1@anta777 or 1usmus_v3, program will exit, restart TestMem, it'll work.
hello! i downloaded testmem5 with the config files from the first page. i think i have figured out how to run everything,renaming cfg to MT.cfg to get it to run. unfortunately the test that runs is always 3 minutes 30 sec. every time. is there something im doing wrong? ive seen others mention running the test for couple hours.
this was my log:
Hit 'Load config and exit' browse to your TestMem/bin folder, load Extreme1@anta777.cfg or 1usmus_v3.cfg, program will exit, restart TestMem, it'll work.
2472409
Reactions: SgtRotty
thank you! what percentage should i set it at?
I run Extreme1@anta777 overnight on my 3950x at 1500%, 3 cycles, and it takes close to eight hours. But a quick 1 hour test I run 1usmus_v3 at 1000% but only 1 cycle. Always when that passes Extreme1@anta777 at 500% will pass 3 cycles as well.
cool thanks for the info! 1 last question, in your last pic it says customize: Extreme1@anta777 . mine says Default @serj . is that something im doing wrong? nvm figured it out
Discussion starter · #37 · (Edited)
@munternet
I think the explanation for the errors is only valid with the default .cfg and the 1usmus_v3.cfg.
I know, for example, if you compare that Extreme1@anta777.cfg and the 1usmus_v3.cfg the tests are different like Test 2 is a totally different test than Test 2 in the second .cfg.
I think the default MT.cfg and 1usmus_v3.cfg tests match.
Maybe a link to a detailed explanation of the errors to the type of test like Function=RefreshStable, Function=SimpleTest and Function=MirrorMove etc. would clarify?
If you want, when I find the time, I could make a list? But then the User would have to check the test type in the .cfg when they get an error and compare it to the list if not running the 1usmus_v3.cfg.
Discussion starter · #39 ·
@munternet
Thanks, I will add a note (y)
Question regarding awe, To enable awe you must run with administrator, I do run it as admin and it's gone when I reboot, so what exactly is that confirmation and why I don't get it again even if I delete the folder and run it again
