PCIE Frequency???
119K views 18 replies 14 participants last post by  StenioMoreira
#1 ·
PCIE Frequency - The default is 100MHz,raising this improves texture loading times across the board (due to faster data speeds and increased available bandwidth over the PCIE bus) "safe" settings for this are between 105 - 110MHz.
What is the downside to taking it to 115 or 120 and what is the upside does it help overclocking......
I figure it could case graphic pixelation and such but as long as the graphics look good and your not overheating you should be fine!!!!
#2 ·
Tweeking up the PCIe to between 107-112 can improve stability in an OCed system. Beyond 112, according some can damage the Vid Card.
#4 ·
Raising the PCI-E bus won't damage the card, however, because the PCI-E and Sata bus are linked it could potentially corrupt or throw off any Sata drives in the system and cause a loss of connectivity.
As a general rule of thumb stay below 120.
#8 ·
Originally Posted by iamme View Post
I set mine to 107MHz
Seems to work fine allowed me to go from
Core Clock 492MHz ---> 497MHz
Memory Clock 1.16GHz --->1.18GHz
SLI -- XFX6800XT
Gave you tried using coolbits?
It will allow you to overclock much higher than that.
#12 ·
got the latest dirvers and it let me max my core and memory
Core 700MHz
memory 2.8GHz
it runs but its not stable so ill take the bus to 110 and see if that helps
optimal as determined by nvidia control panel is
Core 600MHz
Memory 2.5GHz
Thats nearly double just by updating my driver and yes I use coolbits
#15 ·
Well since this was bumped, I might as well add/clarify...
Increasing the PCIE Frequency only increases the frequency of the bus... the information being relayed back and forth from the video card will never require that much speed so increasing it gives NO increases in performance/stability... in fact, there's a chance of damaging the card and/or motherboard...
If you want it in analogy form:
You have
3 cars going 55MPH on a 4 lane highway
Will this be any different from
3 cars going 55MPH on a 6 lane highway?
NAY!
#16 ·
That effect seemed to work on the NF4 chip set... beyond that not a clue.
I can say for a fact, it improved my OC on the DFI SLI-DR 939 MB!
#17 ·
Originally Posted by killa_concept View Post
You have
Actually, yes there is a difference. Because the rest of the people on the highway drive at a normal speed of 75mph, they will eventually have to overtake those three guys. Most people (at least where I live) who drive that slow on a highway don't even care about looking in their rear view mirror to see if anyone else wants to pass them anyway, so the rest of the people will have to cram themselves into the only lane left, creating a nice traffic jam. On a 6 lane highway the jam won't be as bad.
This applies to the PCIE bus as well. The correct analogy would be:
If three cars are going at 55MPH on a 3 lane highway, they will cause a bigger traffic jam behind them than if they were going at 65MPH.
The whole idea of increasing the PCIE bandwidth isnt because the video cards transfer 4GB of data each second EVERY second (standard speed), but because when the cards need a burst of data (stuff in the ram that didn't fit into texture memory), it will occur faster, creating less of a bottleneck to all the other data transfers that it has to do.
#19 ·
hey guys i have my pcie frequency at 117 mhz so now i wana know what should my plx aux voltage be??? cz i think the plx aux voltage setting is for pcie clock right??? also got plx core voltage and dont know what thats for. they both on auto right now but i had the pc crash during 4k 3dmark test, ran 20 + on regula strike ... but on 4k it crashed so i think it was due to the aux and core plx being auto. give me a voltage to set it too pls bcz i suspect auto is putting too much juice in it, as auto always does
