CPUDoc now features a custom dynamic power plan with ultra low power in standby:
github.com
These are the custom power plans I've made for my 5950x.
I have tested them as well on a 3800X and 5600G (not very thoroughly).
They should not interfere with PBO boost and provide same or very slightly lower performances but better thermals.
Please check before and after with AIDA64 memory benchmark; if there's something wrong the latency could increase by 1 nanosecond.
Update 21st June 2025 (same plans since 2023):
V5 versions for Ryzen 7000/9000 (Win10/Win11)
drive.google.com
Below the v4 versions for Ryzen 5000 and older
Updated 2nd of December for Windows 11.
CRITICAL FIX FOR Windows 10 & 11: no more USB voltage drop-outs
You need to have already the correct SOC and VDDG voltages to fix the USB drop-outs.
Also, if present (but I have never seen it as an option), you have to enable USB Selective Suspend in BIOS.
Renamed the custom "Ultimate Performance" to "Ultimate HighPower".
New naming scheme and introduction of Ultimate LowPower for Win10.
Installer Download
ManniX_Custom_Power_Plans_V2.zip
Window 10:
The recommended for Performances is the Ultimate HighPower, followed by the Ultimate LowPower and Balanced Snappy (which is an in-between the Balanced and Ultimate).
The Balanced Snappy can be very satisfying for benchmarks, especially in ST performances.
All the profiles are maintaining the peak performances in GeekBench 5 for my 5950X.
The Balanced LowPower can reduce the idle power usage by 5-10W and the temperatures by 4-5° C.
Plus overall reduced temperatures and much lower spikes.
Real world usage is something different and of course Snappy and Ultimate will deliver better responsiveness and performances.
But Balanced LowPower is just a notch behind.
Too much effort to maintain the PP versions; use QuickCPU to change the setting by yourself if you need it
Tip: best would be to use Process Lasso to switch specific applications to use the Ultimate HighPower or Snappy profile only when needed. Or just use CPUDoc.
Windows 11:
If you are using Windows 11 and care about performance and latency use the Ultimate HighPower or Ultimate LowPower plans.
There's a bug in W11 power management which is causing all plans except Ultimate to have increased and spotty latency and low boost peak clocks.
I have received some reports about W11 plans being not much responsive also on Intel, therefore I guess it's not only related to AMD.
You can verify testing with AIDA64 memory latency test.
AIDA does not work really well with W11, it will give you very often spotty and inconsistent results.
Test only at fresh boot, close all the open tabs in Edge before rebooting or else they'll be loaded in background.
Don't run the whole benchmark with Cache & Memory, double click only on the Latency box in Memory row.
The first run should give you the peak boost clock, not always though. Mine went to up to 5125 MHz for the first time while it was stuck to 5075 MHz before.
The latency on the first run is usually bogus; wait 10 seconds, repeat, wait, repeat, etc.
You should get a much better latency on average, more consistent between runs, and some much lower scores than with any other plan.
I managed to get a 54.7ns, which is only slightly above the 54.4ns result from Win10, while with any other plan I couldn't go below 55.2ns (with very often 57-58-61-66ns).
Performance delta between Ultimate and High Performance plan can be seen also in Sandra Inter-Thread Efficiency test.
It's quite hard to compare as the results are very very inconsistent over runs thanks to Windows 11.
Anyway you should see an average improvement of 0.5-1.0ns on Inter-Thread latency and quite some substantial bandwidth improvements with specific data set sizes.
The most relevant metric seems to be the "Aggregate Inter-Thread Bandwidth" under "Performance vs. Speed" which improved for me from around 35 to 45 MB/s/MHz
The Ultimate LowPower is excellent; better average power consumption with a small edge in idle but still same great latency and boost and same benchmark scores as the full Ultimate.
The Ultimate HighPower is as expected with minimal power savings, very consistent results.
The Balanced LowPower is really only recommended if you want maximum power savings and lower temperatures.
The latency and boost clock drop is quite substantial and the performances lower.
It does have the power slider but I couldn't see a very big difference in power consumption between the settings.
The difference with Ultimate LowPower seems so small that I would recommend to use it instead of the Balanced LowPower.
Here's a performance comparison between the standard Windows High Performance & Ultimate Performance plans vs my custom Ultimate Performance V2 and Ultimate LowPower V2:
As you can see the Ultimate Performance plan is trashing High Performance and all the other standard plans by a big margin.
Ultimate Performance V2 has a small edge vs the standard Ultimate plan and LowPower is just below it.
Let me know if you experience issues.
Custom plans for Windows 11
AMD Ryzen™ Ultimate LowPower
For Windows 11
Modified out of the Ultimate Performance plan so it doesn't the Power Slider.
It's a performance oriented plan with excellent latency but still has a lot of performance saving features enabled with great savings and lower temperatures.
Highly recommend as daily driver.
NEW 02/12/2022 v4:
AMD Ryzen™ Ultimate LowPower 11-v4-Backup-2022.02.12-17.49.08.pow
AMD Ryzen™ Ultimate HighPower
For Windows 11
It's a performance oriented plan with excellent latency, almost no compromise but still delivers good idle power consumption and low temperatures.
Recommend as daily driver if you want always the max and don't care about power savings.
NEW 02/12/2022 v4:
AMD Ryzen™ Ultimate HighPower 11-v4-Backup-2022.02.12-17.49.15.pow
AMD Ryzen™ Balanced LowPower
For Windows 11
Modified out of the Balanced plan so it has the Power Slider.
It's a nice compromise between performance and power consumption in the middle setting for the slider.
It does have increased latency, lower boost clock and performances vs the Ultimate plans.
Not recommended unless you want to squeeze every possible watt in energy saving.
NEW 02/12/2022 v2:
AMD Ryzen™ Balanced LowPower 11-v2-Backup-2022.02.12-17.48.54.pow
Custom plans for Windows 10
For Windows 10
NEW 02/12/2022 v1:
AMD Ryzen™ Ultimate LowPower 10-v1-Backup-2022.02.12-17.03.34.pow
For Windows 10
Quite reactive to user input; should behave same as Balanced or better.
Slider to the max will keep the vCore high and will be a bit more reactive, in the middle vCore will drop down in idle.
NEW 02/12/2022 v11:
drive.google.com
For Windows 10
Modified out of the Ultimate Performance plan so it doesn't have the Power Slider.
It's an almost no-compromise for performances, slight increased power consumption but yet nice temperatures in idle.
NEW 02/12/2022 v7:
AMD Ryzen™ Ultimate HighPower 10-v7-Backup-2022.02.12-17.09.05.pow
AMD Ryzen™ Balanced Snappy
For Windows 10
It's a more power hungry profile focused on responsiveness with autonomous mode enabled.
Less spikey than the Ultimate, sometimes with better ST performances.
Best suited for Audio/Video and Professional, lower IPC/DPC latency.
NEW 02/12/2022 v3:
AMD Ryzen™ Balanced Snappy 10-v3-Backup-2022.02.12-17.04.03.pow
How to install
1 - Download the installer
2 - Use QuickCPU
Download and install QuickCPU
View -> Power Settings -> Power Plan Management -> [Import]
Select the power plan file (pow extension) and click [Activate & Close]
2 - Manually using the Command Prompt
Download the POW file.
Start a Command prompt with Administrative privilege (search for command prompt in start menu).
Import the plan with
Please use the full path where the file is located and enclose it in quotes.
Replace the directory name as needed.
You can use the
Tools
QuickCPU
coderbag.com
Highly recommended if you want to make your own customizations or compare with other profiles
Release v1.2.17 Beta · mann1x/CPUDoc
v1.2.17 Beta New: Partial re-factoring of the engine to lower CPU usage, now an average of 0,02% CPU load with SSH and PSA enabled Fix: NumaZero now should work properly
AMD Ryzen™ [Zen4-3D] Ultimate v5 2023-05-29.zip
Installer Download
- Updated Intel Custom Plans
- Balanced LowPower, Snappy, High Performance are same, just changed naming schema
- Added Ultimate LowPower and Ultimate HighPower
Window 10:
Which are the specific conditions or use cases when it could be better to use the PP versions?
While with the non PP version:
In practice nothing will scheduled on the 2nd CCD unless needed.
With 1 CCD processors everything will be scheduled on the best processors and nothing on the lower CPPC Perf cores.
This is because Windows Scheduler is considering a Ryzen Processor as an heterogenous architecture, despite not being one.
All the lower perf cores will be considered as Efficient and all higher perf as Performant.
The previous custom power plans where fixing the Scheduler issues forcing the policy for heterogeneous to prefer Performant Processors and prefer Efficient Processors for background threads.
With the latest Scheduler this is not needed anymore; now it's finally doing it with the Automatic settings.
This means not anymore hacksaw temperature graphs and spikes.
There are some cases as mentioned above where it could be more convenient to force the background task policy to PP.
In general it's not recommended; for a very small single thread performance increase in normal usage the temperature goes up a lot and the spikes are huge.
With some workloads, mainly benchmarks, could be useful because often the Scheduler is just mistaken an spawns an heavy thread on an Efficient Processor.
The EP is not only slower but once the Scheduler realizes the mistake it has to move it to a PP causing delay and additional loss of performances.
- Terrible binning of the non best cores
- Terrible binning of the 2nd CCD
- Static OC with 2nd CCD at a much lower frequency than the 1st
- Very specific competitive benchmarking
Windows 11:
The standard Power Plans in Windows 11 are pretty good. With some exceptions of course.
Microsoft as usual made one step forward and two backwards.
The Scheduler now works pretty well in terms of performances and core idling, impressive improvements versus the previous releases and Win10.
This is mainly because all the profiles are using Autonomous mode and it can finally properly drive a Ryzen CPU.
For instance the vCore is finally going up only when needed and the performances really great.
What is very disappointing is that basically many of the plan settings are completely disregarded.
Plus while running in Autonomous mode is worse, the Scheduler is disregarding even more.
The Autonomous mode in Windows 11 is a big improvement but it's not perfect.
Temperatures and spikes are quite horrible.
That's why I've created only one LowPower custom plan.
Unless you have a problem with the temperatures, just use the Balanced with slider in the middle or max.
Or the High Performance or the Ultimate.
They all are configured mostly the same and deliver mostly the same experience...
Maybe the High Performance has a drop of performances more but it's really one drop in the ocean.
The LowPower will deliver 2-3° C less on idle, same power consumption as Balanced (Why? How? What...) and at least 4-6 °C less during load.
Temperatures spikes are quite decent with LowPower, absolutely awful for all the standard plans.
Microsoft has definitely something to fix there...
Just moving the mouse from one screen to another causes the CPU temperature to jump to 45-48 °C with the Balanced plan.
With the LowPower it's slowly going up to 40-41 °C.
This is achieved mainly disabling the Autonomous mode, plus scheduling tweaking that actually works once not in Autonomous.
Of course the price to pay it's measurable lower performances, about 10-20p ST and 50-60p MT in GeekBench 5.
All Windows 11 Power Plans have prefer PP for background threads.
Forcing otherwise is hardly taken into consideration by the Scheduler.
For Windows 11
NEW 02/12/2022 v4:
- Fixed USB voltage drop-outs
- New naming-scheme to differentiate between Win10 & Win11
NEW 02/12/2022 v3:
Version v2:
Version v1:
- New heterogeneous policy; boost FPS in gaming
Version v2:
Version v1:
For Windows 11
NEW 02/12/2022 v4:
- Fixed gaming performances, now comparable to LowPower
- Renamed to HighPower to differentiate from the standard plan
NEW 02/12/2022 v3:
Version v2:
Version v1:
Version v2:
Version v1:
For Windows 11
NEW 02/12/2022 v2:
- Updated with Heterogeneous policies same as the other plans
For Windows 10
NEW 02/12/2022 v1:
For Windows 10
NEW 02/12/2022 v11:
AMD Ryzen™ Balanced LowPower 10-v11-Backup-2022.02.12-17.03.23.pow
NEW 25/10/2022 v10:
Version v10 (PP):
Version v8:
drive.google.com
Version v7:
drive.google.com
Version v6:
drive.google.com
Version v5:
drive.google.com
Version v4:
drive.google.com
Version v3:
drive.google.com
- Adapted for the latest Windows 10 release
Version v10 (PP):
Version v8:
AMD Ryzen™ Balanced LowPower v8-Backup-2021.25.1-09.04.40.pow
Version v7:
AMD Ryzen™ Balanced LowPower v7-Backup-2021.24.1-13.17.48.pow
Version v6:
AMD Ryzen™ Balanced LowPower v6-Backup-2021.23.1-08.47.01.pow
Version v5:
AMD Ryzen™ Balanced LowPower v5-Backup-2021.22.1-17.39.57.pow
Version v4:
AMD Ryzen™ Balanced LowPower v4-Backup-2021.21.1-17.58.15.pow
Version v3:
AMD Ryzen™ Balanced LowPower v3-Backup-2021.21.1-10.43.29.pow
For Windows 10
NEW 02/12/2022 v7:
NEW 25/10/2022 v6:
Version v6 (PP):
Version v5:
drive.google.com
Version v4:
drive.google.com
Version v3:
drive.google.com
Version v2:
drive.google.com
Version v6 (PP):
Version v5:
AMD Ryzen™ Ultimate Performance v5-Backup-2021.23.1-08.46.46.pow
Version v4:
AMD Ryzen™ Ultimate Performance v4-Backup-2021.22.1-17.39.49.pow
Version v3:
AMD Ryzen™ Ultimate Performance v3-Backup-2021.21.1-18.06.53.pow
Version v2:
AMD Ryzen™ Ultimate Performance v2-Backup-2021.21.1-10.45.17.pow
For Windows 10
NEW 02/12/2022 v3:
NEW 25/10/2022 v2:
Version v2 (PP):
Version v1:
drive.google.com
Version v2 (PP):
Version v1:
AMD Ryzen™ Balanced Snappy v1-Backup-2021.25.1-09.04.49.pow
How to install
2 - Use QuickCPU
powercfg -import "C:\Users\myuser\Documents\filename.pow"
You can use the
%userprofile%
magic keywork to point to your user folder.Tools
QuickCPU
Quick CPU - Real time performance optimization and Sensor monitor
Quick CPU is a real-time CPU performance tuning and monitoring tool that lets you optimize power, core behavior, voltage, and thermal settings for maximum efficiency and control.
First versions (outdated):
The first one is modified out of the Balanced profile so it has the Power Slider.
Min state on my 5950x: 2200 MHz and 0.9V
drive.google.com
The second one is modified out of the Ultimate Power profile so it doesn't have the Power Slider.
It's a no-compromise for performances, slight increased power consumption but yet nice temperatures in idle.
Min state on my 5950x: 2880 MHz and 0.95V
drive.google.com
BalancedLowPower2.pow
RyzenUltimate.pow
