Laatst bijgewerkt: 17 november 2020
AMD Radeon® RX 6900 XT
RX 6800 ⠀⠀ Eigenaarsclub
RX 6800 XT Eigenaarsclub
→ RX 6900 XT Eigenaarsclub⠀
SPECIFICATIES (Klik op Spoiler)
Rich (BB code):
Architectuur RDNA2
Chip Navi 21 XTX
Transistors 26.800 miljoen
Die Grootte 536 mm²
Productieproces 7nm
Stream Processors 5120
TMU's 320
ROPs 128
Compute Units 80
Ray Accelerators 80
Kloksnelheid Kern 2015 MHz
Boost Kloksnelheid 2250 MHz
Geheugen 16GB GDDR6
Geheugenbus 256-bit
Geheugen Kloksnelheid 2000 MHz / 16000 MHz
Geheugen Bandbreedte 512 GB/s
Externe Voeding 8 + 8 Pin
TDP 300W
DirectX 12.2 Ultimate
OpenGL 4.6
OpenCL -
Vulkan 1.2
Interface PCIe 4.0 x16
Connectoren 1x HDMI 2.1, 2x DisplayPort 1.4a, 1x USB-C met DisplayPort 1.4a
Afmetingen (LxBxH) 267 x 120 x 50 mm (2.5-Slot)
Prijs $999 US
Releasedatum 12 december 2020
Rich (BB code):
RX 6900 XT | Navi 21 XTX | 7nm | 536mm² | 26.8 BT | 5120 SP's | 320 TMU's | 128 ROP's | 80 CU's | 2250 MHz | 16GB | 2048MB x 8 | GDDR6 | 256-bit | 512 GB/s | 300W
RX 6800 XT | Navi 21 XT | 7nm | 536mm² | 26.8 BT | 4608 SP's | 288 TMU's | 128 ROP's | 72 CU's | 2250 MHz | 16GB | 2048MB x 8 | GDDR6 | 256-bit | 512 GB/s | 300W
RX 6800 | Navi 21 XL | 7nm | 536mm² | 26.8 BT | 3840 SP's | 240 TMU's | 96 ROP's | 60 CU's | 2105 MHz | 16GB | 2048MB x 8 | GDDR6 | 256-bit | 512 GB/s | 250W
RX 5700 XT | Navi 10 XTX | 7nm | 251mm² | 10.3 BT | 2560 SP's | 160 TMU's | 64 ROP's | 40 CU's | 1980 MHz | 8GB | 1024MB x 8 | GDDR6 | 256-bit | 448 GB/s | 235W
RX 5700 XT | Navi 10 XT | 7nm | 251mm² | 10.3 BT | 2560 SP's | 160 TMU's | 64 ROP's | 40 CU's | 1905 MHz | 8GB | 1024MB x 8 | GDDR6 | 256-bit | 448 GB/s | 225W
RX 5700 | Navi 10 XL | 7nm | 251mm² | 10.3 BT | 2304 SP's | 144 TMU's | 64 ROP's | 36 CU's | 1725 MHz | 8GB | 1024MB x 8 | GDDR6 | 256-bit | 448 GB/s | 180W
RX 5600 XT | Navi 10 XLE | 7nm | 251mm² | 10.3 BT | 2304 SP's | 144 TMU's | 64 ROP's | 36 CU's | 1560 MHz | 6GB | 1024MB x 6 | GDDR6 | 192-bit | 288 GB/s | 150W
RX 5600 | Navi 10 XE | 7nm | 251mm² | 10.3 BT | 2048 SP's | 128 TMU's | 64 ROP's | 32 CU's | 1560 MHz | 6GB | 1024MB x 6 | GDDR6 | 192-bit | 288 GB/s | 150W
De RX 6800, RX 6800 XT en RX 6900 XT delen hetzelfde PCB-ontwerp. De AMD Reference PCB (2x8-pins) heeft ruimte voor 6 voedingsfasen aan de linkerkant en 10 voedingsfasen aan de rechterkant, waarvan ? ervan is toegewezen voor geheugen. Dit betekent dat de RX 6900 XT referentie PCB maximaal ?? voedingsfasen heeft voor de GPU.
AMDMSRP | Model | Lengte | Slot | Ventilator | HDMI | BIOS | Stroom | Fasen | Vermogenslimiet | Boost | PCB | EAN | PN |
$999 | Referentie | 267mm | 2.5 | 3 | 1 | 1 | 2x8-Pin | 16 | 2250 MHz | Referentie |
ASROCK
ASUS
[/TD> |
GIGABYTE
[/TD> [TD] |
